200 Radiator
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Topic: 200 Radiator
    Posted: 13 Sep 2020 at 9:54am
Been watching a coolant leak that was getting worse. Checked it yesterday and the top seam on the front of the radiator at the top is leaking when I pressure tested it. I removed the radiator and will take it to the radiator shop in the morning but with the way the radiator is made should I start planning on just replacing it all together?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2020 at 9:57am
If you take it to a rad shop, they will fix it.  Might need a recore, but that is the way I go.  It will be good for a heck of a long time.  Since you have the rad off, be sure to check the water pump for any slop in the shaft.  I would put new hoses on and replace the thermostat as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2020 at 4:06pm
Previous owner at some time replaced water pump and by pass hose but I will check water pump. I am going to replace radiator hoses by pass hose and thermostat while I am in there
