Tall cylinder head
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Topic: Tall cylinder head
    Posted: 29 May 2020 at 7:33am
What year or tractor serial number was the tall head used on the WD? Parts book shows an engine serial number but I haven't found a tractor serial number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2020 at 7:47am
That's a tough one, as many have had heads replaced over their years of service life. I know my Dad's 53 WD had battery ignition and the tall cylinder head with the newer thermostat housing. Battery ignition was effective at chassis s/n 136,718 which was a 1953 build. I think the tall cylinder head was probably in use by then at least. Sure wish I knew what Dad's s/n was.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2020 at 8:13am
My Grandpa's WD, serial no. 115XXX, which makes it a '52, has the tall head. As far as anyone can remember it was never off. Tractor came with a mag, I converted it to 12 volt and battery ignition.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2020 at 8:58am
My dad's '53 had the curved shift lever and 6 volt battery ignition, can't say for sure but I think tall head.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2020 at 9:25am
 What engine number was listed. There is a chart on Bryan Smith's website that lists APPROXIMATE tractor numbers to engine numbers.
http://wsmth.people.clemson.edu/SNFind/esn_tsn5.htm
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2020 at 9:27am
The "tall" head was introduced in 1951 with "engine" number WD289001.
Finding the exact "tractor" serial number might be a little difficult.
Bryan Smith assembled a correlation of engine/tractor serial numbers which can be found at this site:  http://wsmth.people.clemson.edu/SNFind/esn_tsn6.htm
1951 ENGINE SN Range:    278585-313931
1951 TRACTOR SN Range:   72328-105181
So, I'm guessing the tall head first appeared with tractor numbers in the 80000 range.
My WD with tractor number WD100853 and engine number WD309267PA has the tall head.
NE GA Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NE GA Allis Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2020 at 11:20am
Yes, pin pointing the exact tractor serial number would almost be impossible. If those engine and tractor serial number ranges are accurate for 1951, there was 2,493 more engines produced in 1951 than tractors. I would assume that the extra 2,493 engines were put in combines or used for power units. Maybe even sent to a dealer if ordered.
Keeping Allis alive with:
2 B’s, 1 C, 6 CA’s, 2 WD’s,
1 WD45, 3 D15D’s, 1 D17
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2020 at 12:04pm
Some may have even powered some merry-go-rounds ??………..
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2020 at 7:54pm
My 1951 WD101353 w/ engine WD309752PA has the tall head. As you said it is mentioned in the book at engine SN 289000. The first WD in '51 looks to be 72328. So, my money is on AC changing to the tall head earlier in '51.
I don't know that my engine or cylinder head is original, but TomMN mentioned in my thread that it fits nicely in his chart correlating tractor and engine SNs.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2020 at 5:42am
From my observations over the years, the tall head started to be used on WD's in 1951 around serial number 83,xxx.
This page was generated in 0.031 seconds.
