clutch problem?
sadmyentist View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sadmyentist Quote  Post ReplyReply Direct Link To This Post Topic: clutch problem?
    Posted: 21 Oct 2019 at 10:30am
Hey all, probably a dumb question here.
On my WD45, it seems the clutch slips rather than the wheels spinning when I have an implement really stuck in the ground. (E.g. loader, tumblebug scraper) Sometimes the wheels spin, but sometimes the clutch slips. I don't smell burning lining, so I suspect the oil bath hand clutch.
Is my clutch going, or are there situations where the wheel traction can actually overpower a healthy clutch? What would be the best way to test the clutch(es)?
Thanks in advance!
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 10:35am
If the pto is engauged and not turning when the tires are not slipping then the foot clutch slipping.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sadmyentist Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 10:44am
Aha! Good point! Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 11:27am
Both clutch systems can have issues. The hand clutch can be adjusted by taking out shims. I have not done this but lots of information on here about that.
