ca 125ci oil pressure
caRon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Topic: ca 125ci oil pressure
    Posted: 17 Sep 2019 at 11:13pm
What should the oil pressure be at idle and at high throttle on a CA 125 engine?
CA Tractor
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 11:46pm
I believe the oil pressure is 12 or 15psi from the factory. It will be lower as the engine warms up. Warmed up at idle expect it to be 8 or 10, but depends on how worn your engine is. 5 psi is ok at idle but under load 5 is too low in my opinion.
www.awtractor.com
A&W TRACTOR 920-598-1287
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2019 at 6:48am
On the CA sadly the condition of the engine has (nothing) to do with the oil pressure on the gage. Oil pressure on the gage only shows the pressure between the pump and the oil filter. The volume of oil from the pump flows thru the pump stem into a hollow camshaft some out the spinning camshaft thru little holes to lube the camshaft and main bearings. The rods pick up the oil from the little holes that are in line with the rods thru holes in the rods that pick up the oil as it spins forcing the oil into the rod bearings.
This is the reason it does not take a higher pressure to keep the bearings lubed.
