Off color - Deere M
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: Off color - Deere M
    Posted: 29 Jul 2018 at 8:16pm
I know, I know.  Don't shoot!  My dad has some sentimental attachment - it was his uncle's tractor.
It's been sitting in his cousin's barn untouched for the last 25 years - it ran when it was parked in there.  A couple of issues:
1) The engine does not appear to have any compression.  You can turn the engine with the crank but there is no resistance at all.  The spark plugs are in and everything is complete.  Not trying to start it, just checking that the engine was free.  A little too free it seems.  Any Idea what the problem is?
2) The left rear wheel does not turn.  Transmission is in neutral and jacked up wheel.  It moves a few degrees but appears to get hung up in the transmission.  The right wheel turns freely with no problems at all.  Once again, the tractor was parked there under its own power.
Anyone familiar with these critters?  I am not!
I appreciate any suggestions!
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2018 at 8:45pm
Dad has an M. Check for stuck valves. Spray some oil in the cylinders to lube up the rings. Locked up wheel may be the brake, they have an odd design.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2018 at 8:54pm
Thanks RW.  Are you saying the brake would still lock the wheel even if the brake pedal is not pushed down?
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2018 at 9:43pm
Yes, rust.
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2018 at 5:50am
I agree on stuck valves. Just had that issue working on an Allis G for my brother that had sat. valves were stuck open. Lot of PB blaster and start working them. I would start on that by pulling valve cover and checking.
This page was generated in 0.116 seconds.
