Piston stand out on 433t engine
chuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck Quote  Post ReplyReply Direct Link To This Post Topic: Piston stand out on 433t engine
    Posted: 05 Jun 2018 at 7:30pm
Wondering if anybody knows what specs are for the piston stand out on the 433t engine in the 6080 is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2018 at 10:52pm
sleeve or piston? Can't imagine piston protruding but not worked on one.Think that head is flat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2018 at 11:14pm
Piston, working on one that the block was surfaced and just wanted to check things out while the head was off to make sure things were in speck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2018 at 7:13am
Unless you took off more than .005" there isn't anything to worry about.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2018 at 11:09pm
That's the problem doc, I have no idea what was taken off, I bought the tractor this way and previous owner was half way through a self overhaul and gave up, so just wondering what the correct specs are.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2018 at 5:39am
I've looked thru all my official AC service books and I don't see a thing. Since 1975 I have NEVER had to surface any Harvey engine block and never had any problems. Even if they took .005" off the deck, the counterbores would have to be lowered the same amount. I think you'd better drop in a sleeve without Orings on it and see what that dimension is. I can't imagine they removed very much. A good Machine shop would stamp or tag the block for how much they removed...............
