Opinions on 8070 Allis
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Topic: Opinions on 8070 Allis
    Posted: 20 Apr 2017 at 3:53pm
I have sold my 190 and are considering selling my 1206 farmall. Thinking of going from two old tractors to one decent newer tractor. Found an 8070 locally. Little bigger than I need, but leaves room for expansion. 3500 hrs. What are you guys opinion on these.
Thanks
Adam
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2017 at 5:57pm
I have an 8070 FWA, powershift, and I sure like it. 3,500 hours isn't many hours. Should be a lot of life left in that one. Darrel
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2017 at 6:17pm
The only issue I have ever been told to look out for on the 80xx series, is the FWA input shaft play into the front diff.  Apparently these wear, and are often not in very good shape.  Otherwise, they had many of the updates learned from the 70xx series, and are a solid robust tractor.
Still in use:
fourthgeneration View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2017 at 6:22pm
The only negative I can think of with the 8070 is that it is large 1000 rpm pto only.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2017 at 6:32pm
Get it quick before someone else gets it. If a PS and if 5th gear low and 2nd gear hi are the mph speed, there is a wine in 5th gear. Later ones have different speeds and they don't have the extra noise. Hopefully, the throttle is in the console at your right side. I say go for it. You will love it. You can always add 540/1000 PTO from a salvage yard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2017 at 6:35pm
So, did you call your neighbor to buy it yet? Why not?
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2017 at 6:57pm
If you're going to use it for a loader it may be too big.   Its better as a field tractor.
Nowadays, a good loader tractor has a forward reverse shuttle and maybe lower (smaller) making it easier to get on and off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2017 at 8:48pm
Is it a power director or powershift. Just out of curiosity. We have a Power Director in ours but it only has 2800 hours on it. We also have a 7020 with about 7200 hours on it that has a Power Director.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2017 at 9:25pm
Power director and 2wd. I'm not going to rush into anything, but I will be making a trip back over to look at it again and talk with the owner some more. Surprised that Ilgleaner hasn't bought it yet honestly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2017 at 9:28pm
Now I just need to find a buyer for my 1206. I'm thinking around $9500-$10500 for it. Needs some work, but has new tires, new turbo, and transmission/rear end has been gone through from the high low reverse transmission on back
