B_clutch questions
Tom Elder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Elder Quote  Post ReplyReply Direct Link To This Post Topic: B_clutch questions
    Posted: 11 Dec 2016 at 7:39am
Thanks ahead of time,this is a great forum
 Question one,what is the difference between a solid clutch and one with springs.
Question 2 is it possible to just replace the 3 release levers ,and where could you obtain new ones.
thanks again Tom
2 1949bs,one with belly mower one with side sickle bar
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2016 at 9:10am
The original factory discs had segmented facings that used a thick one against a thin one and they were alternated on each side. That allowed only half of the facings to make contact at the very beginning of engagement.  If your going with all new stuff those are no longer available and you can only get the full circle lining, for which which you'd want a spring loaded center. I have a lot of NOS clutch parts available, some linings and levers.  Do you have an 8-1/2" disc or 9"? There were also a couple different pressure plates used at the factory, that used different parts.
