Need a WD45 gas crankshaft
Jamie NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie NC Quote  Post ReplyReply Direct Link To This Post Topic: Need a WD45 gas crankshaft
    Posted: 31 May 2010 at 9:03pm
Ok guys still need a gas crank with good mains that can be turned no more than 0.020 undersize. Rod journal don,t have to be good at all, will welding them up.Send PM with what you have and the  price and shipping cost to zip code 28613.
Thanks Jamie Sigmon
Allis tractor puller CA WC WD D17
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie NC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 12:33pm
BUMP
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 12:45pm
I have a WD45 shaft there in KC MO. that will need to be turned down, I'll look tonight and see if it will work for you.
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 5:16pm
If you plan on welding the rod journals what difference does it make if the mains are a little under? They can be turned, welded, and ground back to original size if needed.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 6:08pm
He is not wanting the expense of having the mains welded as well but enough meat to turn the mains in under to straighten the crank after the rod journals have been welded and offset ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 7:07pm
OK I just looked at my shaft, The good news is rods will cleanup at .030. The bad news is the mains need to be cut down to .030 too. Let me know if you can use it. The price will be right. This shaft is out of a 1957 WD45.
Don
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 8:17pm
  we have wd45 crankshafts will check inventory  need phone #
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie NC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 9:53pm
Mlpankey, Knows what I am after.Yes you can weld all of the journals but that cost alot more money.
 Norm, send PM on this site with what you have and price with shipping to 28613.
Thanks in advance.
Edited by Jamie NC - 01 Jun 2010 at 9:54pm
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 7:41am
i have a wd 45 crank that has been rough welded and needs to finished ground
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 7:42am
call this number and talk to keith , he had it a couple months ago. 5635828710
