D-17 spitting oil
Crowman17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crowman17 Quote  Post ReplyReply Direct Link To This Post Topic: D-17 spitting oil
    Posted: 26 May 2010 at 8:04am
     Just noticed my 17 has oil comming out the engine breather and running down side of the block I was brush hogging with the tractor. The engine is in fairly good shape starts good no noises with good compression and doesn't burn oil never had any problems with it. If you take the breather off the oil is being sprayed against the breather from the valve train. Is there a shield inside or something that may have broke off to stop the spray? Haven't taken the valve cover off yet. Maybe oil passage blocked and oil can't drain from cover? Is that possible? It's a Ser IV gas.
Marc
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 8:09am
Crowman17, There is a shield on top of the rocker arms. Pull the valve cover and see what is going on in there.
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 9:06pm
Make sure the oil feed line to the rocker arm shaft isn't broken off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crowman17 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 9:45am
    Dr. Allis, you were right the oil tube to the rocker assembly popped out of hole and was spraying oil all over. Two minute fix thank goodness. New $17 valve cover gasket done good as new.
    Marc
This page was generated in 0.056 seconds.
