Allis Chalmers 8070
Justin(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Justin(IN) Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 8070
    Posted: 20 May 2010 at 12:33pm
i'm going to go look @ an Allis Chalmers 8070 two wheel drive (82' model).  What are some key things to look out for? as i'm not familiar with these tractors...
If there are any pros and/or cons about an 8000 series tractor will be helpful as well.
Thanks for the help...
Justin
niel ev View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote niel ev Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 12:56pm
Justin the only big disapointment in a 8070 is the big 1000pto shaft kind of limits what you can do with it you can put the 540 1000 shaft in it its just a little time consuming Niel
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 2:10pm
I think they are good tractors , the big thing I believe or what Ive heard is the main bearings in the engine ; 5000 hrs is time to change them ; but then again alot has to do how it was serviced , and how it was ran , some ole tractors have had theres guts pulled out + Ive got a couple of those !!!!
