Snapcoupler subsoiler
steve(oh) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(oh) Quote  Post ReplyReply Direct Link To This Post Topic: Snapcoupler subsoiler
    Posted: 17 May 2010 at 6:14pm
Had a guy wondering if it was possible to convert a pre snapcoupler subsoiler to fit a snapcoupler tractor.(take a eye off a plow and bolt it to the subsoiler).  I told him the only thing that worries me is if the length of the subsoiler  would be to long.  Did not know if anyone on here has ever messed with converting one?
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 6:38pm
I just leave a wore out drawbar on it.
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
NCAllisnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 7:34pm
Mine was a pin hitch, I think.  It is not made like the drawbar mounted subsoilers.  The lift arms are made to bolt to the lift arms on the tractor.  After seeing the pictures of the 3 bottom plow flipped upside down on the seat, I am not so sure it is a good idea to bolt lift arms on!
Adam
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 7:45pm
Adam, The bolted lift arms are OK with a pin hitch, unless the pin breaks.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 9:22pm
 Back to the original ? , assuming it is a pin hitch presently, yes it will work if it is switched to an eye and has the pin arms put on for lift latches.
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 11:33pm
REMINDER TO SELF :
   add safety chain
   get clutch kick out put on
   convert bolt ons to latch pins
2014 HD Tri Glide
