ID engine
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Topic: ID engine
    Posted: 24 May 2016 at 6:38am
I've got supposedly a D14, but can't read the torque tube numbers.
I've got the engine number : 149-13754R    that last letter I believe is an "R", could be an H or A, not completely sure.
Trying to ID the year,model  etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2016 at 9:41pm
Well, it's a G-149 engine. If it has a spin-on oil filter like a PH8A Fram, it's a D-15 series 1 engine. If it has the cotton string oil filter like a WD45 with the steel tube up inside it, it's probably a D-14 engine....could also be D-10/12.
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2016 at 6:28am
it has 2 sealing rings at the bottom of the sleeve bores. I'll check on the filter tonight. it's also cracked at the bottom between 1 & 2 just don't know how bad yet. but bad enough probably... looks like rust and crud was the only thing keeping it from leaking.
As I was tearing it down, I saw the worst rebuild of any engine I've ever seen. Who'd SHIM a Main Bearing, and Why? at one point, the thing had tossed a rod thru the side, and they'd done a wonderful job of JB Weld "Bondo" on the thing. It's smeared on the inside and out. there's evidence of damage everywhere even 3 of the 4 sleeves had a piece missing at the bottom.
I think I recovered most of the tractor serial# 143543  was all I could read, so I'm thinking '58 D14.
Edited by corbinstein - 25 May 2016 at 6:29am
