Long wheelbase 8000 series |
Post Reply ![]() |
Author | ||
Josh in Pa ![]() Bronze Level ![]() Joined: 22 Aug 2014 Location: s.e. Pa Points: 47 |
![]() ![]() ![]() ![]() ![]() Posted: 31 Mar 2016 at 7:50pm |
Mostly curious, but will have the fwa axle off my 8030 this week. What does it take to move the axle forward? Mine has a large unmachined casting (I assume where the 2wd axle would attach) in front of the fwa axle. Does this get removed? How far do guys move them forward? To the same spot the 2wd axle sits? (110"?). It looks fairly easy, remove the casting, mag drill some holes, longer hoses and lengthened driveshaft. Will it help the ride? This is my only Allis, but it's pretty rough riding.
Josh |
Sponsored Links | ||
VAfarmboy ![]() Silver Level ![]() Joined: 06 Dec 2013 Location: Virginia Points: 470 |
It probably won't help the ride enough to be worth the trouble. How much fluid do you have in the tires? We have an old 4440 John Deere (longer wheelbase than an AC) that rode rough as hell and we we let some of the fluid out of the tires and replaced it with wheel weights and it greatly improved the ride.
427435 ![]() Orange Level ![]() Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
More air and less fluid is a good suggestion. A new seat with fore/aft free travel will also help (reduces back slap).
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
ILGLEANER ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |
It will help the ride. It will cut down the turning radius. You don't take that bolster out, it holds your frame rails. Most of them get moved all the way forward. Don't forget about changing your hydraulic filter under there. I prefer, if it can be done, about half way from where it is, to as far as it can go forward. The farther you move it forward, the lower your front end will get, makes them look a lot better when the azz isn't dragging .
IG |
I'm a little slow, and not an Allis guy, but that 2wd bolster is exactly in the way of moving the fwa axle forward. Are there different ones maybe? And what do you mean by hydraulic filter? I thought I changed them both recently and they were down low in the back?
Josh |
cowkicker ![]() Orange Level Access ![]() ![]() Joined: 21 Mar 2010 Location: Ky Points: 529 |
You will need to take a power hacksaw and cut that piece of casting off. Then remove the four bolts that hold the axle support to the main frame and roll the support forward until the original holes in the back of the support line up with the original front holes in the main frame, that leaves only the front two holes to be drilled.
AllisandGleaner ![]() Silver Level ![]() Joined: 04 Mar 2016 Location: Sc Points: 360 |
Sounds complicated!
eighty nine ![]() Silver Level ![]() Joined: 13 Nov 2013 Location: ILLINOIS Points: 96 |
Edited by eighty nine - 02 Apr 2016 at 7:26am |
Peterson ![]() Orange Level ![]() ![]() Joined: 05 Mar 2011 Location: Westboro, Wi Points: 866 |
Done it on all three of our 8000's. Would do it again in a heart beat!
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Acfarm ![]() Bronze Level ![]() Joined: 05 Oct 2014 Location: Portland,Or Points: 143 |
Good info! Been considering doing that on my 8070 at some point....
What was the reason for the original short base? ~Warren
Probably to give it a tighter turning radius than a John Deere. Edited by VAfarmboy - 02 Apr 2016 at 8:42am |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8648 |
Poke your nose under the front end.There's a filter up in there that's out of plain view.Could be re-mounted anywhere on the tractor...but not many places to choose from. |
They looks so much bigger when stretched out.
NEVER green ![]() Orange Level Access ![]() Joined: 28 Feb 2013 Location: MN. Points: 8615 |
The tightest turning FWA for many years.
2-8050 1-7080 6080 D-19 modelE & A 7040 R50
Reason this one looks bigger is because of 20.8r42's and 16.9r28's! Lol
Michael V (NM) ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: NM Points: 2483 |
ought to be stuck to the ground with those tires,,, got duals?
That tractor sure looks tough with the big tires and longer wheelbase.
Josh |
She is pretty tough! This is the way they shoulda came from the factory.
coggonobrien ![]() Orange Level Access ![]() Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1864 |
I assume you had a custom drive shaft built?
Yup. A tad thicker tube for it. Local machine shop guy did all three of them for us.
Allis 8050 ![]() Silver Level ![]() Joined: 29 Dec 2014 Location: Western PA Points: 52 |
Did moving the axle affect the turning radius at all?
AC C, D-15,D-15II,ONE-SEVENTY,185,200,7010,8010,8030,8050 AGCO LT90a, AGCO RT130 and GLEANER R55
A tad but not much. Cant really notice it very much.
Where did you get the rims for the 20.8-42 tires
Our local tire dealer. Just a step up rim to go from 38" centers to the 42" tires.
Post Reply ![]() |
