Single Digit Midget B at upcoming auction?
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Topic: Single Digit Midget B at upcoming auction?
    Posted: 28 Apr 2010 at 7:18pm
I was looking thru the local auction house upcoming auctions and one of them has a 1937 B with serial #4.  Looks to be in fair shape.  Don't know that much about the Bs other than I kinda would like one.  Engine does look different though - the early ones were Waukesha's weren't they?
cheers,
Creek
Edited by Creek Jenkins - 28 Apr 2010 at 7:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 7:28pm
Yes they were...
Steve@B&B
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 7:31pm
I looked at the pictures of the Waukesha B that Dale Haymaker has on his Paris museum website, and I'm going to say that that's not a 1937 B at that auction. At the very least the engine looks like the standard BE engine, maybe CE. They're probably just misreading the serial number. But I could be wrong.
The manifold should be visible on that side of the tractor if it were a Waukesha flat head.
I guess it's possible that the engine was replaced? I know some things weren't interchangeable with the 1937 B's and the later ones... not sure about the engine. Can't say I've ever had much personal experience with one of them!
Edited by wjohn - 28 Apr 2010 at 7:35pm
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 7:38pm
wjohn, I agree with you.  That is not, repeat, not, a Waukesha B.
With the mag on the shown side that is a standard B or later B engine.  You can see by the plugs and the plug openings.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 7:39pm
Definitely not a 37 B Waukesha engine. I wish they had a better picture but the engine is a BE or CE.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 7:41pm
That is a Waukesha B, all except the engine and the hood, & perhaps the radiator cowl.
The engine has obviously been replaced.
It would still be a neat tractor to own.
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 7:42pm
Take a look at the fenders.  I believe that this may be a hybrid of early B and later B parts...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 7:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 7:45pm
Sorry, I am still in the infancy stage posting pictures.  This is me at "Coming Home" with Nan Jone's Waukesha B.  Not the greatest picture but note the manifold and air cleaner hose on the engine side.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 7:46pm
Now I'm really curious - might have to slip over and have a look at it if I can get off work early.  Just to see what it goes for.
cheers,
Creek
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 7:49pm
The rear fenders, the front wheels and axles and the serial number sure do point out that it started out in 1937.
Life was harder after that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 7:51pm
Here's the pic.  Definitely not a Waukesha.  If the s/n is korrect, then it was repowered and a diff hood put on.  Or did they just not scrape away enuf paint to see all the s/n?
Curious!
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 7:53pm
Ah, those front wheels and fenders definitely are different... well I'm learning plenty about 1937 B's today! It sure would be neat to see it at Paris in July if someone on here gets it, even with the replacement engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 7:57pm
It kinda looks like the tool box is bent to fit the torque tube. That would be from the 37 too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 7:59pm
See how the hood does not line up with the fuel tank? That, and the fact that the holes are in all the wrong spots make it obvious that the hood was replaced, probably when it was repowered by that newer engine. Something probably broke or wore out on the Waukesha and the owner took the opportunity to "upgrade".
The rear fenders are flat, which is the way the first 96 were made, as they fabbed the fenders by hand, supposedly. If it has the brass plate with serial number 4 on it, then it is definately a 1937 from the torque tube back.
If someone wants to buy it, I would trade a couple of my NOS IB pintle hitches for it, as I believe there are fewer pintle hitches left than Waukesha B's.  Let me know.
Edited by GlenninPA - 28 Apr 2010 at 8:00pm
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 8:10pm
Some of you guys have forgot more than I'll ever hope to know about orange
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 8:15pm
I have to agree. Same front wheels as Waukesha B (if I remember correctly) and fenders as well. Throttle control is mounted in the proper place for it as well. It's quite a bummer it doesn't have the original engine. The torque tube looks shorter as well. It's surely an early B if it has the brass tag.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 9:29pm
I agree with Lou.  I'll never be able to keep track of all the different quirks.  Have enough trouble with keeping D17s straight.
If I can get over to the auction, I'll try to get pics of it.  We are supposed to go fishing that day with some friends, but odds are 50/50 the wind will keep us off Red so I might make it.  Maybe Bruce will be there and he can tell us about it.
cheers
Creek
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 9:48pm
I think Glenn is right.. it was a 37, but the motor is a BE.. other parts sure look llike original 37.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 9:52pm
closeup of tool box, and steering column, (no light switch box)...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 9:55pm
the original 37 should have a real long wheel hub that sticks out further than later models... and a 6 bolt pattern.
Dale H. ECIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale H. ECIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 10:01pm
Since it has had the engine changed to latter B engine the radiator would have to be changed, also it should have split rims on the rear, can not tell with all the chains on it.
Correct fenders, throttle and front wheels at least.
The brass tag would be worth as much as the rest of the tractor, I think the lowest 1937 B recorded so far is #16, mine is #18.
Allis Chalmers Museum, Paris, Il.http:// www.allischalmersmuseum.com 217-275-3428
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 6:32am
Dale,
On the owners registry, (if you get past the spam), number 1 is listed. I arranged most of them into the correct year sequence based on the serial numbers.
Glenn
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale H. ECIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 6:45am
Glenn,
 The last time I checked with Larry Mathew, he is making a registry of the 1937 B's, he said #16 was the oldest one he had on his list. I did not check the registry on here.
  He said most of the ones on the list DID NOT have a brass tag on them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 10:05am
Probably Larry should email  him...
B 1937 1 Tom Treloar
Clear Lake Iowa Not Looking to Sell
Edited by GlenninPA - 29 Apr 2010 at 10:06am
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 3:16pm
I know a big time AC collector who is going to the sale with a thick check book!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 7:11pm
Is that a threat?
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 7:40pm
It sure looks like a nice hike up into North Minnesota....
ASEguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ASEguy Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2010 at 7:07am
Bill,  Your tractor is beautiful.  Excellent paint.  It looks museum quality.  I have a 48 C with a long restoration road ahead.  Would love to see more pics if you have the time to post them.
Gerard
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2010 at 4:46pm
ASEguy,
If you are refering to the picture Bill Long posted:
The tractor is not Bills. Bill lives in Maryland and sadly no longer has a place for a tractor where he lives now. BUT he does hold a special place in his heart for anything and everything AC. Bill was the son of a small AC dealer that sold many, many B tractors in their area. It is his favorite tractor. Bill is a great reference here and we all appreciate him VERY much and always love hearing what he has to say! He is a great man!
The tractor is, or was, owned my Nan Jones, the previous publisher of the OAN. It was one of the first 96 B's ever produced that used the Waukesha engine.
