Rewiringwd45 |
MB 121
Joined: 02 Feb 2016 Location: Waggoner Il Points: 21 |
Topic: Rewiringwd45Posted: 19 Jun 2026 at 5:41pm |
I am rewiring a 1953 wd45 has a 3 wire alternator, 12 volt coil and a 6 volt starter. I have some questions. First would it matter if I ran the sensing lead on alternator to the out put post and eliminate it running back to the key switch? Second my key switch has two hot wires 1 should run to the coil and the second should run to the exciter wire for the alternator? Third my amp gauge hot side should run to the starter? Trying to clean up the wiring bundle that is on it. I got wiring that was run splices and black taped into a 2" mass complete with wire nuts butt splices the works.
Edited by MB 121 - 19 Jun 2026 at 5:42pm |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5472 |
Posted: 19 Jun 2026 at 6:06pm |
I've seen slap-dashers wire a small light bulb between the alternator and exciter wire. Light goes out after alternator starts charging and comes back on when engine stops. There are many ways to wire an alternator, so pick your poison. I would get a one wire regulator if I didn't what to do the wiring the way the alternator requires.
MB 121
Posted: 19 Jun 2026 at 6:30pm |
I was under impression that a 3 wire is regulated internal.? I'm not trying to run it wrong to avoid a spice or wire this thing Is a mess I'm trying to basically cut it at each end and rerun new wires. Just figured hooked to out put post it's still sensing the line voltage of the system if I were to go to petronics system that's the way they recommend wiring it from what I've seen.
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1437 |
Posted: 19 Jun 2026 at 11:31pm |
Steve@B&B has harnesses for those.
Jim.ME
Posted: 20 Jun 2026 at 5:28am |
The Delco 10SI 3 wire type alternators are internally regulated. You can run the wire from the sensing spade terminal to the Battery stud on the alternator and it will work on a small system as the WD45 has. Large systems as in vehicles it should be connected nearer to the battery to take into account all the electrical components drawing off the system.
You can use the accessory terminal of a 4-position ignition switch to excite the alternator. That is not the common method, but it will work as long as the ignition is on the ignition terminal of the switch and the wire to the alternator's excitation spade is on the accessory terminal. One thing to be aware of is that power will go to the alternator excitation spade if the key is turned to the accessory position when the engine is stopped, which will drain the battery.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7725 |
Posted: 20 Jun 2026 at 9:02am |
Petronix has nothing to do with how the alternator is wired.
MB 121
Posted: 22 Jun 2026 at 12:25pm |
Thank you for info I will keep it in mind when running new wire
Joined: 11 Sep 2009 Location: illinois Points: 93399 |
Posted: 22 Jun 2026 at 1:42pm |
the 3 wire 10SI needs an excitation wire to turn it "ON"... Easy way to get that is a small drop in voltage on that wire compared to the rest of the system.. As Paul said, some use a small light bulb... some use a diode... i use a small resistor... They sell them on ebay or Amazon for a couple bucks...
Posted: 22 Jun 2026 at 1:48pm |
the above is for a PUSH ROD starter... If you have a solenoid and key switch/ button... it looks more like this....
MB 121
Posted: 22 Jun 2026 at 7:19pm |
Thanks for wiring schematic much appreciated mine would be pushrod key.
MB 121
Posted: 22 Jun 2026 at 7:24pm |
I will just run the sensing lead back to key switch it works the way it's wired now it has a magnetic pull the current way it's wired so from what I've read it's working. Correct
