more stepchild 220 woes |
Post Reply |
Michael V (NM)
Orange Level Access Joined: 12 Sep 2009 Location: NM Points: 2365 |
Posted: 06 Apr 2020 at 3:40pm |
Ya reckon this is why the power steering quit,,,no other hydraulic functions tested...
I kinda cleaned the case where this filter goes,, I will get more serious later... Do the Gurus have a good way to clean the final drive/transmission without a total disassembly? hyd oil.. how do y'all flush the rest of the system? I should have took before pictures,,, this is after 2-4 hours with the hot water pressure wash.. |
CrestonM
Orange Level Joined: 08 Sep 2014 Location: Oklahoma Points: 8365 |
Can't help ya, but Yikes!! Got it looking good where you've been cleaning, though...
Dave(inMA)
Orange Level Joined: 12 Sep 2009 Location: Grafton, MA Points: 2395 |
What is that crud all over the filter? Looks ugly. I don't have a cure for cleaning contaminated hydraulic oil out of a beast like the 220! I've been cleaning it out of my little CA - just drained the Hytran out of the various compartments and let it sit for a few days. And flushed the two hydraulic pistons.....a minor project compared to yours!
Dave
WC, CA, D14, WD45
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7984 |
My my my,, that needs a good flushing for sure
Lonn
Orange Level Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29781 |
Dump in a bunch of cheap 303 oil. Run it for a half hour or so.... drive, run hydraulics and drain it all out again. That's what I would probably do.
Edited by Lonn - 06 Apr 2020 at 8:38pm |
Wink I am a Russian Bot |
Michael V (NM)
first, that white stringy crap is Teflon tape...the rest is mostly rusty, dirt crap, there is some shiny metal flakes,,, I'm hoping that's not too serious...but I know that means something has been wearing more than it should.....this filter/strainer has probably not been seen it was installed 51 years ago at west allis...
Lonn,,, that's exactly what I thought I'd do, I'm hoping that 10-15 gallon will do it for flushing,, just running around no load, and kinda warm things up a bit, so it drains well I have thought about taking the shifter and back cover off(the one under the fuel tank) and getting after it with the pressure washer,,,,and I can look at the case and gears, bearings and such...
DCAC
Orange Level Joined: 20 Oct 2018 Location: east central SD Points: 511 |
Would diesel fuel work instead?
Michael V (NM)
yea,,, it might,,,thought of that too
DCAC
Maybe less chance of getting rust started vs. powerwasher, especially if it has to sit for awhile afterwards?
Lonn
Does anything rust in New Mexico?
Acdiesel
Orange Level Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2525 |
I've used Diesel fuel and Mineral Spirits, usually fill the case and run the tractor for about one minute and drain it.
I don't cycle valves. the advantage with mineral spirits It will evaporate as the fluid gets hot if you don't drain it all out of the lines. you could remove the lines and blow them out with Air. Dan
D19 diesel,D17 diesel SER.3 D14 NF,D14 WF, D15 SER.II wf
D15 SER.2 DIESEL,D15 ser.II nf D12 SER.I, D10 Ser.II 2-720'S Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
Post Reply | |
