Looking for special tool
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Topic: Looking for special tool
    Posted: 29 Jul 2012 at 4:10pm
Anyone have the special socket for the Gleaner 9/16" feeder beater fingers, AC TP 1007, that I could use or buy?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2012 at 4:18pm
You can cut a deep well socket in two and weld a length of pipe in between. I just worked through the inspection holes with a hand wrench.Put a little blue loctite on new ones. Can't remember if I was able to get a box end over the end with the guide out or not.
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2012 at 9:39pm
i used a pipe wrench but i replaced it and the new one had a hex at the top it was 5/8 on f2
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2012 at 7:52pm
Never mind.  My new fingers are 5/8" with two flats at 1/2" wide on the end, and I don't know if it would use the same tool as the 9/16" fingers. I will grind out a 1/2" square socket to work.
