Looking for Hd6 part
Jgriffis03 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgriffis03 Quote  Post ReplyReply Direct Link To This Post Topic: Looking for Hd6 part
    Posted: 18 Mar 2026 at 9:42pm
I’m needing the intermediate shifting shaft. If anyone has one for sale I would greatly appreciate it. Number 5 on the callout for parts diagram of the shift tower. Thank you in advance
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:20am
Have made that exact part a couple of times in the past. 4140, or 4340 Alloy steel will offer enough surface "toughness" without heat treat to last. Have a machinist bore the shift handle, (#6) round and bush this with oilight bronze, or drill and tap your new shaft, (pivot pin) for a grease zerk, and cross drill for grease path keeping it tended to. While the shift lever is out always a good idea to have the lands where the pivot screws butt against cleaned up also. Makes for a nice tight shifter again as long as the shifting forks and shafts are in good condition. These always need touched up also as wear items.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:31am
 What’s the part number
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgriffis03 Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:45am
I’m sorry all, it’s number 6 on the callout.
P/N: 098089
Or
P/N: 086705
It’s the whole lower shaft
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgriffis03 Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:46am
The whole shift lever is missing haha. My issue is that I’m not sure I can get one machined without precise measurements of one first.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 40 minutes ago at 3:07pm
Maybe check with General Gear and Machine in Boise, Idaho
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 12 minutes ago at 5:35pm
Definitely be cheaper to obtain used, but I can make one if needed.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgriffis03 Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 27 minutes ago at 9:20pm
How much would you charge for one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgriffis03 Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 48 minutes ago at 9:59pm
I checked there and they said the one they had they just threw out because it was worn out
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 32 minutes ago at 11:15pm
Forum member gemdozer has some parts but he said his yard is closed until Spring, also, he is in Canada
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 38 minutes ago at 4:09am
No real idea as time and materials would be in play. Realistically probably $350 - $400 is in the ballpark. I have a good piece/pattern to follow. Have never made one complete as you need but have rebuilt several.
Before putting much into this tractor I'd suggest you manually get into each gear and operate it. You can do this by moving the shift forks with a pry.
Seen a lot of 'Starry Eyed" auction, and sale  purchases over the years reveal underlying buget busting problems underneath requiring wheelbarrows rather than shovelfulls of money to fill the pit.
Edited by Codger - 5 hours 53 minutes ago at 4:54am
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgriffis03 Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 31 minutes ago at 9:16am
Little back story here, it was parked up about 40 years ago and I bought it for 600 bucks and I honestly didn’t have the equipment to pull it out of there so as the mechanic I am I got it running an drove it out of the hole it was stuck in. The only thing I need to do now is replace some hydraulic lines and free up steering clutches. I did try and shift in all the gears hand itinerary shifts pretty smooth and they all grab
