Long wheelbase 8000 series
Josh in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh in Pa Quote  Post ReplyReply Direct Link To This Post Topic: Long wheelbase 8000 series
    Posted: 31 Mar 2016 at 7:50pm
Mostly curious, but will have the fwa axle off my 8030 this week. What does it take to move the axle forward? Mine has a large unmachined casting (I assume where the 2wd axle would attach) in front of the fwa axle. Does this get removed? How far do guys move them forward? To the same spot the 2wd axle sits? (110"?). It looks fairly easy, remove the casting, mag drill some holes, longer hoses and lengthened driveshaft. Will it help the ride? This is my only Allis, but it's pretty rough riding.
Josh
VAfarmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VAfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2016 at 9:20pm
It probably won't help the ride enough to be worth the trouble.  How much fluid do you have in the tires?  We have an old 4440 John Deere (longer wheelbase than an AC) that rode rough as hell and we we let some of the fluid out of the tires and replaced it with wheel weights and it greatly improved the ride.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2016 at 9:49pm
More air and less fluid is a good suggestion.  A new seat with fore/aft free travel will also help (reduces back slap).
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2016 at 10:04pm
It will help the ride. It will cut down the turning radius. You don't take that bolster out, it holds your frame rails. Most of them get moved all the way forward. Don't forget about changing your hydraulic filter under there. I prefer, if it can be done, about half way from where it is, to as far as it can go forward. The farther you move it forward, the lower your front end will get, makes them look a lot better when the azz isn't dragging .
     IG
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 4:38pm
I'm a little slow, and not an Allis guy, but that 2wd bolster is exactly in the way of moving the fwa axle forward. Are there different ones maybe? And what do you mean by hydraulic filter? I thought I changed them both recently and they were down low in the back?
Josh
cowkicker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 4:55pm
You will need to take a power hacksaw and cut that piece of casting off.  Then  remove the four bolts that hold the axle support to the main frame and roll the support forward until  the original holes in the back of the support line up with the original front holes in the main frame, that leaves only the front two holes to be drilled.
AllisandGleaner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 6:18pm
Sounds complicated!
eighty nine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eighty nine Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 7:28pm
 Done one several yrs. ago this same way. Improved the ride quite a bit & would make the turn in on 12-30's with a little help from the brake.  Not a bad job & could easily be moved back original if you didn't like it. I think we narrowed the front weight bracket a little to help turn shorter also , otherwise tires would rub hard.
Edited by eighty nine - 02 Apr 2016 at 7:26am
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 7:48pm
Done it on all three of our 8000's. Would do it again in a heart beat!
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Acfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acfarm Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 11:04pm
Good info! Been considering doing that on my 8070 at some point....
What was the reason for the original short base?
~Warren
Post Options Post Options   Thanks (0) Thanks(0)   Quote VAfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 8:29am
~Warren
Probably to give it a tighter turning radius than a John Deere.
Edited by VAfarmboy - 02 Apr 2016 at 8:42am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 10:26am
Josh
Poke your nose under the front end.There's a filter up in there that's out of plain view.Could be re-mounted anywhere on the tractor...but not many places to choose from.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 7:59pm
Here's a pic of the first one i did.
Weight bracket extension.
And I cut both ears off for the the 2wd axle.
Any questions, I'd be happy the help.
Edited by peterson - 02 Apr 2016 at 8:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2016 at 8:21am
They looks so much bigger when stretched out.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2016 at 8:49am
~Warren
  The tightest turning FWA for many years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2016 at 2:49pm
Reason this one looks bigger is because of 20.8r42's and 16.9r28's! Lol
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2016 at 9:34pm
ought to be stuck to the ground with those tires,,, got duals?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 7:54am
Last year in the spring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 8:28am
That tractor sure looks tough with the big tires and longer wheelbase.
Josh
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 8:53am
She is pretty tough! This is the way they shoulda came from the factory.
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 9:04am
I assume you had a custom drive shaft built?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 9:11am
Yup. A tad thicker tube for it. Local machine shop guy did all three of them for us.
Allis 8050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis 8050 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 9:41am
Did moving the axle affect the turning radius at all?
AC C, D-15,D-15II,ONE-SEVENTY,185,200,7010,8010,8030,8050 AGCO LT90a, AGCO RT130 and GLEANER R55
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 10:21am
A tad but not much. Cant really notice it very much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis 8050 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 1:34pm
Where did you get the rims for the 20.8-42 tires
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 2:01pm
Our local tire dealer. Just a step up rim to go from 38" centers to the 42" tires.
