I thought of the anti bio fuel nuts today |
Page <12 |
FREEDGUY ![]() Orange Level Access ![]() ![]() Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Why is this political ?? And you DID comment
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54157 |
Politics is downstairs, so, No comment...
victoryallis ![]() Orange Level ![]() Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
JW
The anti bio fuel folks blow my mind. Why would you be against something uses commodities and in turn helps prices because you can’t maintain your system. Every bushel that gets consumed is a good thing. |
JW in MO ![]() Orange Level ![]() ![]() Joined: 16 Feb 2010 Location: South KC Area Points: 2666 |
When i saw this post I thought, What the Hell? It was posted to spark a fire, hence the juvenile name calling, “because you don’t believe what I believe.” It was not posted to convince anyone of anything, just separate “believers,” and “nonbelievers.”
There’s enough of that crap happening in today’s world, move on. |
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5097 |
It's like the BioDiesel, don't let it sit in our humid climate. BioDiesel goes sour like a jug of milk, so starting it on occasion may help, but you have to use it up, if the fuel sitting in the tank is a year old, it's going to be sour if it is a high content of bio. I am no chemist, but the pumps coming in gummed up seized and won't run is happening more and more. DO NOT RUN BIODIESEL IN A TRACTOR THAT SITS A LOT! Us fuel pump rebuild shops can't keep up as it is lol! Some say it's good for business, but it's not the good kind of business.
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12192 |
Yeah victory, but you don't live where it's humid and you get temperature swings! Hahahahaha
......Cue Dave Kamp book on alcohol.
Alex09(WI) ![]() Orange Level ![]() ![]() Joined: 15 Mar 2012 Location: CECIL WI Points: 1751 |
You should consider yourself lucky. I have seen time after time in my repair business where the ethinol itself breaks down into a slime and cloggs up the carburetor jets and passages where the fuel system would otherwise be clean.
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 3090 |
Well mine runs fine on non ethanol gas not so fine on ethanol contaminated gas.You're probably referring to the old 66-88 models with the fully enclosed engines.
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 3062 |
Many of those Oliver's vapor locked years before Ethonol was in the gas. Why are so many of them missing the side shields now?? Ford's did too.
When I used to cut hay with a D10 on a hot day after running it for about 30minutes it would start to run poorly,take the hood off and it would be fine apparently the alcohol in the gas was causing vapor lock.Went back to 100% gas solved the problem. I leave the side panels off my Oliver 1550 gas so the heat of the motor isn't heating the gas tank.About the only people I know that claim to like Ethanol are those financially benefiting from growing corn.Ironically the largest seller off non ethanol gasoline in my area is a farmers coop.
AaronSEIA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2573 |
Same here. Pulled the carb apart on my 25 year old rebuilt WC. Inside looked like the day I put it together and had E10 in it 100% of those 25 years. AaronSEIA
Lars(wi) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Permian Basin Points: 8085 |
Just up the street from my son’s house, A Murphy Oil gas station will soon open, the sign say’s ‘ethanol free gas available’.
Hope it will be the 87 octane variety, don’t want to pay more for the higher octane grades. Some Walmart’s also have ethanol free gas, but not any that I know of in the Midland/Odessa area. |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87936 |
Still saw, tree trimmer. 24 HP B&S mower, couple B tractors, 2 cars, Pickup .... all no problems.
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
I don't have any problems with it, not even in my Stihl chainsaww.
Seems like it's the guys that run STIHL equipment that have issues
SLee(IA) ![]() Silver Level ![]() ![]() Joined: 11 Sep 2009 Location: Polk City, Iowa Points: 269 |
I'm with you Victory. Our WD45 was bought new in 1953 by my dad. Don't use it much now. Run an auger once in a while or move a wagon. Been running E10 since it became available 30+ years ago. Starts with a touch of the starter and runs great.
Steve
Ed (Ont) ![]() Orange Level ![]() ![]() Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1500 |
I run regular gas in everything I own including chainsaws. No problems.
Put gas in my D17 fall of 2019 don’t use it much so a 2.5 gallon can lasts awhile as long as remember to turn the gas off. I start the tractor 4-5 times a year to move it. Doesn’t get 15 minutes a year run time. In the process of converting my storage shed to a shop so I’ve ran it some more shuffling stuff around. She’s running like a top with gas containing ethanol. Proof a clean fuel system doesn’t need ethanol free gas.
Edited by victoryallis - 14 Jul 2021 at 7:14pm |
Page <12 |
