Grandfathers CA
 Post Reply Post Reply Page  <1 111213
CA13414 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2025 at 5:49pm
Glad to hear the ole' girl is running like a champ!  Now go put that puppy to work!  Thumbs Up
Steve@B&B
Thanks again Steve. Impressed with how good our little friend runs. It rained here to day, thus, will put her to work next weekend. However, did run until hot and then adjusted timing for a smooth running engine. Here is another link if interested.
Edited by CA13414 - 03 Aug 2025 at 8:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2025 at 1:31pm
Finally was able to put our "little orange friend" to work. Ran spectacular and did not drop out and misfire after warming up.
With the rain these past weeks, some of the sand had washed down and into the lake. This despite all the catch basins and drain tile we have put in.
With the CA and blade and harrow, was easy to pull up the sand from the water edge to fill the ruts and regrade.
However, I didn't take a single picture.... FAIL!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2025 at 4:38pm
Re the clunk, before tearing down the final, double check the PA wheel clamps...Wink
After tightening up the final drive with repairs on the hand clutch, it was better, but there was still a clanking when on the road. Thus, as DiyDave mentioned, the "Eccentric Pins" that hold the rim tight keep coming loose.
The shop manual, "...each eccentric pin must be fully turned to the right to be tight." I was not getting them turned fully to the right, thus would keep coming loose quickly when used.
I finally was able get the job done with a 24' cheater bar and a 9/16" Female Plug Socket
Edited by CA13414 - 16 Sep 2025 at 6:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2025 at 4:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2025 at 4:45pm
This worked awesome to get all the eccentric pins rotated fully to the right. It was not difficult with the cheater and working each one as I rotated the wheel and put each on top.
No clunking on the highway!!! Thanks for all the advice and hints.
Edited by CA13414 - 16 Sep 2025 at 4:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2025 at 6:37pm
Next projects:
   1) Take some the shims out of the PTO shaft and see if that tightens the play in the differential we have on the PTO and pulley. Hope it works as Chris/Sugarmaker was able to do.
   2) Also need to work on the pulley seal which still leaks oil a bit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2025 at 8:05pm
CA13414,
Just a note removing the PTO shims did tighten the drive system in the PTO. I ended up replacing the seal and putting the shims back in to allow the PTO to spin easily.
Chris and Cheryl
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2025 at 8:14pm
Thanks Chris,
I think I will order a new seal for the PTO and the Pulley. Then remove the shims and hope it tightens up.
Our is so loose, I can hear it when the PTO is engaged to run the hydraulics and 3-point lift.
Just sounds like a gear that is about to jump a tooth and tear up the drive.
Dan
Edited by CA13414 - 16 Sep 2025 at 9:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2025 at 8:00am
Dan,
Good luck on improvements to the gear box system I dont know anything about the internals of these.
 Chris and Cheryl
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 55 minutes ago at 10:20am
Chris, the "Fire and Ice Poppers" were awesome! Basted them before they went on the smoker and halfway through cooking.
Dan
Edited by CA13414 - 5 hours 52 minutes ago at 10:23am
