Grandfathers CA |
Page <1 101112 |
Author | ||
CA13414 ![]() Silver Level ![]() Joined: 25 Feb 2024 Location: Nebraska Points: 333 |
Yes, I did replace the coil and condenser a month ago. It still misses after warming up.
Today all I did was change the points. It is clean and not grounded. Only the condenser and coil are attached to the point. Edited by CA13414 - 19 Jul 2025 at 2:32pm |
Sponsored Links | ||
I did recheck everything. Not sure why, but I simply disassembled everything then put it back together. I was able to get a shock off the coil contact which was OK but not a hard snap of a shock. Must of had a contact and grounded out the coil somehow.
However, after timing the rotor gears there was nothing to the plug wires. I took off the distributor cap and with a screwdriver touching the coil contact, there was a shock. As well there is pressure on the cap contact rod, thus, I think this is OK. Shop is hot and I am drenched. Back inside for a bit with a cold one. Dan Edited by CA13414 - 19 Jul 2025 at 4:11pm |
Earlier I watched a "youtube" rebuild and the shock they had was an arc of about 1/2". Not what I am getting.
Maybe a rebuild however, not to keen on the idea of $325. Dan |
However, after reading the various threads, everyone who bought a rebuilt magneto mentioned it was a very good move.
The "youtube" on rebuilding a magneto mentioned "recharging" the magnets! Is that a thing? Maybe that is why "my shock" is a pansy ass shock. Dan Edited by CA13414 - 19 Jul 2025 at 8:41pm |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87228 |
i have several B tractors all with MAGS.. I have replaced coils and condeners and points as needed over the years.. I had ONE that was REAL STUBBORN on starting after a few years.. I took apart the the IMPULSE SPRINGs were weak and not retarding the spark to TDC when you crank.. It was OK when i turned by hand.. I finally got it to work "OK"..... couple months later there was a guy on this site going out of business and was selling his REBUILT MAGS... had 3 or 4... Said complete rebuild with RECHARGED MAGNET / new coil / NIS condenser / etc. ... so i bought it... WOW... what a difference.. Engine rolls over ONCE and its running.. HOT SPARK.. FANTASTIC... Never thought i would get that much DIFFERENCE !!
Edited by steve(ill) - 19 Jul 2025 at 8:00pm |
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 1214 |
Yup, it is indeed a BIG thing. All else being equal, spark energy is (somewhat) proportional to magnet strength. And magnets lose strength as they age, requiring periodic re-charging. Back 'in the day' every significant tractor dealer had a magneto re-charging machine. I wish I owned one
Steve, so maybe a rebuild or different mag with a "recharged mag" will help?
Interesting. That may be the issue. Dan Edited by CA13414 - 19 Jul 2025 at 8:43pm |
Les, thanks for the comment. All that makes since. Maybe the rebuild with a magnet "re-charge" is a good option as you and Steve mentioned. Much appreciated to everyone! Dan Edited by CA13414 - 19 Jul 2025 at 8:37pm |
Thinking about this and the role of the magnet..... to induce a current. If the magnet is weak, the induced current is weak, or for me a pansy ass spark.
Who here does a great job of "re-charging" a magneto? As noted, I did find someone on the "internet" who does this but would feel more comfortable with someone here in the group who knows a good :re-charger!!!" :') Edited by CA13414 - 19 Jul 2025 at 8:48pm |
jvin248 ![]() Silver Level ![]() ![]() Joined: 17 Jan 2022 Location: Detroit Points: 444 |
Are the magnets "alnico"? Common 1950s magnet chemistry. Alnico loses strength over time. More modern use ceramic that don't lose strength. If you buy a pair of strong rare earth magnets off temu/Amazon you can recharge the magneto magnets. Mount to a bench vice and run your magneto magnets between them. Don't pinch your fingers. . . |
here are a few good photos... half way down the page is the "magnetizer" to recharge oil magnets... guy has a "HOME PAGE" button at the bottom..
Here is recharging a guitar pickup magnets, made of alnico. https://youtube.com/shorts/26zdiZ6xRhw https://youtu.be/ufhUd4wkPMs There used to be a video where strong magnets were stuck, setting correct polarity of each, to the faces of a vice to control the space to slip a magnet between and charge it up. . Edited by jvin248 - 20 hours 29 minutes ago at 1:37pm |
Thanks Steve, quite an amazing process. Is neat to see how we use to do this with the magnetizer. I also went to his home page and saw the AC collection which was awesome! There was also a number of fun links. Dan Edited by CA13414 - 2 hours 4 minutes ago at 8:02am |
Thanks for the links..... was neat to watch. |
Appreciate everyone's insight into the Magneto and lack of spark. Has been fun to learn from everyone. :')
Despite the effort thus far in "rebuilding" the Magneto (cap, wires, points and etc), I decided to replace it with a distributor conversion kit. Will still try to re-magnetize the rotor just to do it.
This week, I ordered a drive unit and an electronic distributor from Steve at ""B&B Custom Circuits." Excited to install this and get the CA back up and running! Edited by CA13414 - 2 hours 5 minutes ago at 8:01am |
You will not regret switching to a pointless distributor
Page <1 101112 |
