Grandfathers CA
 Post Reply Post Reply Page  <1 91011
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2024 at 9:15am
Thus, with new wires, plugs, rotor and cap, is this the magneto coil that is cutting out at high temp or the magneto condenser? Connections are tight. Maybe replace both??
Your right on track... Could be either, or both..
CA13414 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2024 at 4:20pm
Just ordered both from DJ's..... I am hoping this resolves the issue. I think I will change one at a time to see which is the culprit offender!!
Edited by CA13414 - 02 Sep 2024 at 4:40pm
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2024 at 4:59pm
Just for info, CAs with engine prior to CE149840 came with magnetos, those from CE149840 and on came with distributors.  My 1952 CA13092 has a distributor.  I have no idea whether that's original or not.  Would be interesting to know where CE149840 broke in but didn't see that on the AGCO site.
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2024 at 9:03pm
Interesting!! Let me pull the serial number form our "farmed in" CA. Definitely it is a magneto and I will bet you are right..... Our farmed in CA is an earlier number than the number of my grandfathers CA.
As well, as I type, I do remember that our family CA does have a distributor. This would make sense.
Dan
