Got one fixed and then,,,,
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: Got one fixed and then,,,,
    Posted: 27 Dec 2016 at 8:00pm
    something else pops up,,,,
  I had a thread on my D14 Industrial gettin hot on me and popping a freeze plug in the cylinder head, and dumpin water into the oil.  Well,,I finally got part of that problem squared away,,but wound up I had to make a thermostat housing cause I could not find one anywhere, to replace the broken housing.
 I made this little number using 2 pieces of 3/8" plate steel and machined a register for the Chevy V8 180° thermostat. I used a S/40 1" X 2" concentric reducer and welded it  to the top plate. There has to be two plates as the opening in the head is way bigger than the thermostat.
Filled with fresh oil and put a spark in it,,,,and engine started right up and after a bit  thermostat opened up and started circulating water,,,,thas good,,,,,but I noticed the oil pressure gauge was settin on 10# and not movin up as the engine used to carry 28# oil pressure at high idle,,,,?  I loosened the filter and just a little bit of oil was coming out of riser tube,,,,? oil had a little tint of milk but mostly good oil,,,
 I raised the filter to bout halfway up riser tube and got good oil pressure, so screwed filter back down,,,but gauge still at 10#,,,,,,WTH,,,,??????
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2016 at 8:10pm
besides all that other....nice fix on the T-stat
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2016 at 8:11pm
old style filter uses the filter to raise oil pressure, so the dirtier it gets the higher the pressure is. Its not like a modern filter, like the PH8A that a 15(II) has.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2016 at 8:37pm
    Thanks SteveM,,,,Clap
  Hey Dave,,,,,when I first fired the 149 up after the rebuild,I installed a new Fram C159 and since the filter did not have that many hours on it,,,I left it in there as I was gonna run the engine for a couple of hours to help clean up some of the milky oil. Then dump that oil and put fresh oil in it along with a new Fram C-159,,,,,
   I'm really puzzled with the low oil pressure now since it carried lots more before it blew the freeze plug and got a little hot on me,,,????  I use Pennzoil 10W30 both times.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2016 at 9:17pm
Joe, I think I'd pull an oil sample. JMHO I doubt if you've really hurt your engine, but anti-freeze can hurt bearings pretty quick as you know. An oil sample is cheap ins.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 2:11am
Pennzoil?????? WTF???? only ones that use that stuff is kids, and that's only cuz they give them stickers to put on their bedroom walls! just as well puts a used filter on it, yer putting used oil in it! PfffffT!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 2:13am
oh....and nice job making that housing!
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 8:32am
    ""Pennzoil?????? WTF???? only ones that use that stuff is kids, and that's only cuz they give them stickers to put on their bedroom walls! just as well puts a used filter on it, yer putting used oil in it! PfffffT!""
     OUCH,,,OUCH,,,,OUCH,,,,,,OK,,,Shameless,,,I GIVE,,,I Give,,,,,but you know,,,I coulda went to the Dollar Store and,,,,and,,,got some of their Elephant oil if thet woulda suited you a tad better,,,,,WinkLOL,,,but their can don't even list the weight of the oil so you don't even know what you gettinLOLLOL
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 9:05am
Oh, man Joe. Shameless hit you pretty hard there. But then he tells you good job on the tractor Stat housing. The t Stat housing does look good. As for the Pennsylvania crude, oops, I mean the pennzoil, well, .....I ain't saying nuttin. Lol Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 9:49am
     Chit Darrel,,,I'm just glad he likes me a little ,,,,,,,,can you imagine if he didn't,,,???  chit,,  I would have to go to sleep standin up alla the time,,,WinkWink
    Anybody got a clue whats happenin with the lower than normal oil pressure on the D14,,???
 Gonna scrounge around ,,see if  I got a spare gauge I can try,,,DAMNG  I is worried some,,,,,
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 5:58pm
Maybe try a heavier oil although a ton of guys here are running 10-30. I use 5-40 in my WD45. You could use 15-40 rotella or something like that in your neck of the woods. I use 5-40 for better cold starts up here in the nord. Funny that it would change pressure all of a sudden.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 7:25pm
Joe, I insist. Do an oil sample test. Or drop the pan and check the last bearing to get oil. You can also lose pressure from the cam bearings. Do something, just don't run it anymore until you find out the problem. Why couldn't you pull the filter, take out the stem and put a master gauge in it's place and see what happens. Haven't done it but seems feasible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 8:32pm
   Hey Leon,,,I did some experimentin today and did find the i/8" line from filter housing to gauge was air locked or somethin,as oil would just dribble out of the fitting behind oil pressure gauge,,,  Disconnected the line at the filter housing and oil shot out of there at a pretty good clip,,so blew the little bitty line out with air and hooked it all back up and oil pressure went to the "O", but used to go to between the R and the M,,,?? I ordered a new gauge thinkin the gauge may be part of problem,
 I'm goin to drain the 10W30 oil tomorrow and put in some straight 30W OR 10W40 (gasp) Elephant Oil from the Dollar Store to satisfy ole Shameless ( my arse still a little sore)
   Is the riser tube threaded into the housing,,?? I tried to unscrew it with some channel locks but it would NOT move so i stopped fore I break it off,,,,,????
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 8:41pm
that tube is pressed in the housing,, needs to be good an tight...
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 4:26am
Joe...do I gots to come down there and kick you in the gona....! why are you putting 10 cent oil ina 3000 dollar engine? would you rather drink clean water or coal oil?
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 4:42am
   Good Mornin Good Buddy,,,,,!!!!
   Well,,you know,,,I sometimes get accused of bein thrifty,,,er frugal,,,,Ummm,,,,cheap too,,,,,!!! but I was just tryin to use oil to flush out the milky water/oil gook outa the engine 'fore I put some "GOOD" oil like,,,,,,Pennzoil,,,or somethin like that,,,may even try some Havoline,,,,,WinkWink ('member that?)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 5:43am
What's wrong with Shell Rotella?
That's better oil pressure than I have on my C, WC and one of my WD45's.....nuthin wrong with that..........You're gonna get ulcers worryin bout nuthin!!
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 6:16am
Joe, you should make more of those. I bet they would sell! Nice work, that is a damn good weld!
Can't fix stupid
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 7:22am
Joe if that engine was already broken in then you could use any old oil for the flushing but I'm of the belief that if it's still in the break-in process then you need to have good oil in it, even if it's just for a few minutes. I also think that all bets are off on the oil pressure as long as there is some water in that oil. I think it would be a hard call as to weather to get an oil test or to just run it and see if the pressure returns after another oil change. It will need to be brought up to temperature and kept there to remove all that moisture at some point IMO.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 8:57am
2x
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 8:59am
Joe I am in the crowd that saids do t worry about the pressure right now worry ab I UT getting that oil clean and all the water out of there that antifreeze will do bad things if you don't get it iut!
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 9:01am
      Hey Ted,,,I'm goin to Wally World here in a minute and I'm gonna look for some of thet Shell Rotella and give it a whirl,,,,,Clap
     Hey Thanks AJ,,,,,I did the stringer and hot pass with my old Lincoln and Hobart 7013 while rolling the housing on a CS rod. It being S/40 carbon steel,,,it oughta last a hundred years,,at least better than the pot metal one,,,,,Wink
    Hey Stan,,,yeah,,the engine is still "breaking in"  as it barely has 9 hours run time on it,, is why I'm so dang picky with it. Fingers crossed on the results with new oil (again) ClapClap
     THANKS for all the kind words,,,,,,,,Clap
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 11:16am
My Dad farmed for over 50 years and always used Pennzoil. He NEVER had to have an engine overhauled. Guess what I've used for 40plus years?
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 12:02pm
They all meet the spec they are certified at. Older engines weren't so picky. With these newer engines you have to be certain the oil meets the manufacturer's specification. I ignore the Jiffy Lube places when they tell me I have to return for a change in 3000 miles. That's 1970s thinking. Either that or they use dirt cheap oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 12:09pm
They use recycled crap oil so yes you need to get back there that soon.... or get it done somewhere that uses good oil and actually puts the drain plug back in...
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 6:19am
    Hey Guys,,,I think I got her solved,,,,!!!Clap
    I have been a Pennzoil man for many many years and so far had not seen a reason to change,,,,until I read Don(MO)'s post on the zinc no longer being added in today's Pennzoil,,,I guess I just hadn't taken the time to actually "READ" what is NOT in their oil anymore. I see where this thread has generated another somewhat contentious thread bout lubricating oils and I want to add my .02 here and maybe on the other thread as well.
    Back when I was still getting paid for workin,,,I initiated a grass roots, In House, survey to "Standardize all the Lubricating Oils Used in the Refinery" There were several different divisions and seemed like every division used different viscosity,, grade and even different Brands of lube oils in their various rotating equipment, that were identical to others in other units,,!! Talk bout a CF,,,usually some pumphouse would run out on a weekend and NOBODY else had that same oil available,,,and when I got caught on Weekend Duty,,with that mess,,we had to dump a compressor reservoir so as not to mix the different lubes,,,and I decided we would no longer fight that battle.
   I worked with the techies from Mobile, Royal Purple and Pennzoil and after several weeks of studies and proposals,, we switched the entire refinery lube stocks to Pennzoil, primarily based on availability, Cost, with the zinc additive also being a consideration. All the Compressors were changed to Dexron II, which,,after some complaints and concerns  from the different Mfgrs about the Dexron II in THEIR compressors,,,finally agreed that Dexron II WAS a viable replacement....
 Long story short,,(yeah right),,as Don(mo) states,, the zinc in Pennzoil was for the older pre 1975(?) engines with the flat tappet camshafts and I had not realized that they no longer had the zinc in their oil, which is good to know when you have some of the older machinery that needs the zinc in their lubricating oils. I will continue to use the Pennzoil in my newer vehicles that DO NOT require the zinc,,,,,Ya hear thet Shameless,,,,?Wink
  SO,,,,while at Walmart, the other day, I did some reading and ,,,,,,I brought home some,,,,,,,,,,,,Rotella in 15W 40 for the D14,,,,,,Clap
  I had plumbed up a 0-60 pressure gauge right off the oil filter housing, and added the Rotella and put a spark in it and the  gauge went to 35# and gradually came down to,,,,,,,,,,,,28# after engine was at operating temp,,,,I'm a HAPPY CAMPER again,,,,,,then I switched back to the old gauge,,,and it only goes to just under the "O" so thet gauge is findin itself a new home,,,,,,,Clap
 Many " THANKS",,Guys,,, for all the help,,,and the kind words,,,,ClapClap
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 7:57am
Joe you should just do like the job did and swap all yours over to the new stuff... lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 9:28am
Whew, glad you have that problem fixed. Now when Shameless dumps 4 feet of snow on you, it'll be ready to move it. Off subject, a little, does that D 14 backhoe have the forward reverse shuttle shift on the big handle, or do you have to shift it to reverse in the transmission. ...? Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 9:53am
Good job Joe. Glad you didn't do it the way I suggested. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 10:26am
  Hey Darrel,,,yeah,,it being an Industrial D14,,,it has the shuttle shift on the left side and I'll tell you,,,it sure is a handy thing to not have to shift the transmission,,,just move it forward or backards,,,,Clap
   No problem Leon,,I just appreciate all comments and suggestions,,,,thas how I learn,,Clap
This page was generated in 0.260 seconds.
