Gleaner E3 traction drive belt |
Joe Graunke
Joined: 14 Sep 2009 Location: Clayton WI Points: 659 |
Topic: Gleaner E3 traction drive beltPosted: 19 Aug 2016 at 1:20pm |
Was wondering on the adjment for new traction drive belt what it needs to be set at
Thanks Joe |
Skyhighballoon(MO)
Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Posted: 19 Aug 2016 at 4:52pm |
Joe - I set mine as tight as I can make that "half moon" metal tension adjuster go. Doesn't seem that tight to me. Never have a slippage issue on my hills though. Mike
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
MACK
Posted: 19 Aug 2016 at 10:27pm |
Adjust until there is 1/4" between shaves at bottom in slow position. Adjust, run to hi and back to lo until you have the 1/4". MACK
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3649 |
Posted: 19 Aug 2016 at 10:44pm |
make SURE it doesn't run on the pins in high speed... or vibrate, which means slack in the bearing to shaft play or a brg down.
