Needed D-17 series 4 rearend housing
WI D-21 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WI D-21 Quote  Post ReplyReply Direct Link To This Post Topic: Needed D-17 series 4 rearend housing
    Posted: 15 Feb 2012 at 7:57pm
The inside of our d-17 rearend housing has a alot of wear where a shaft passes through it. It looks like the bushing got stuck to the shaft and wore the housing. The local machine shop said they could not do anything with it.
Thanks ahead of time.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2012 at 8:34pm
I have one from a 170, but it is still full of good gears $$$$$$ Also have one from a 185 that is full of bad gears $
ALLIS EXPRESS!
This year:
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2012 at 10:43pm
Which housing and shaft? The only shafts with bushings I can think of is the lift arm shaft or possibly the front of the rear PTO shaft?
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2012 at 11:16pm
Would have one, just need to disassemble Ia 563 652-2949
Post Options Post Options   Thanks (0) Thanks(0)   Quote WI D-21 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 7:20am
It's the front of the PTO shaft.
