Allis be repowered by WC |
WD45_Guy
Bronze Level Joined: 24 Sep 2020 Location: Meigs Co. Ohio Points: 5 |
Posted: 05 Oct 2020 at 9:39am |
I figure this would be the area to ask but can a Allis B, be repowered with an engine from a WC?
Charlie175
Orange Level Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6351 |
Anything is possible
But the 148/160 series of engines will bolt up to it. That would give you 40-50 HP
Charlie
CrestonM
Orange Level Joined: 08 Sep 2014 Location: Oklahoma Points: 8357 |
Say a D15 II engine was swapped in, would the ~500 RPM increase change ground speed much? And should the B drivetrain be able to handle it?
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77723 |
I thought the WC/ WD/ 45 motor took a larger bell housing ? The Smalled D series D 10/ 1/ 15 will all fit.........
If the B had a rpm of 1700 and the D15 motor was 500 RPM more, that would be about 30%... so you might get 2 MPH additional ??
Orange Level Access Joined: 12 Sep 2009 Points: 19508 |
The blood-line of the "B" engine goes like this: Cubic inches of 125-138-149 and 160 cubic inches for the "small-block" A-C engine used in B-C-CA-D10-12-14-15. The W-series engine line started in the WC-WF-WD-WD45 and is considered a "big-block" as compared to the smaller engine. Sure, if you make a smaller diameter flywheel and a 1/2" thick adapter plate for bolting the bellhousing/engine block together, it could be done. Then, there's the sheet metal. Then, there's the fact that if you desire to tractor pull it, you will be allowed a "courtesy hook" at best....no competition.
