Allis F40 fork lift
 Post Reply Post Reply Page  <1 91011
 Rating: Topic Rating: 1 Votes, Average 3.00  Topic Search Topic Search  Topic Options Topic Options
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2022 at 9:07pm
Dave,
 Thank you for the details. I will try to learn some things and get this running better at some point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2023 at 8:41am
Folks,
 The F40 has starting issues, Yea I have only done a farmers tune up, fixing a bare wire going into the distributor and cleaning the points, rotor and cap contacts.
 I am starting to fab the brackets to hold the gas tank. It has been setting on blocks of wood for a while. (I have to age these projects like fine wine):)
If anyone knows the points, rotor and cap numbers please let me know.
Chris and Cheryl
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2023 at 7:55pm
Allis guys,
 Finally getting back to look at the F40.
I would like help identifing the distributor type/ style numbers? would like to go to NAPA and get points rotor and cap.
Also the custom mounting base for the gas tank. It is bolted to the counter weight.
 Chris and Cheryl
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2023 at 11:15pm
With the cap off you may find the distributor tag# if you can use a mirror to see around the back, if necessary. Of course better yet, if you pull the distributor out, as the digits are so small. If I remember right, I think the points are the same as in the Allis tractors. You could pull the cap off one of your tractors and compare.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2023 at 6:04pm
Eric, Folks,
 I will try those ideas, thank you! This cap has screws holding it to the base, compared to the other Allis tractors we have. I have a new set of points for the CA. I will look at those.
 Chris and Cheryl
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2023 at 7:52am
Here is a link to a Website that might be some help with your Forklift.
G
https://www.forkliftaction.com/forum/allis-chalmers-forklift-help.aspx?t=27489
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2023 at 10:29am
Gary,
 Thanks! I did look at that site. I need to do some more work to find tune up parts. That may help it start better!
 Chris and Cheryl
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2023 at 3:16pm
Folks,
Just playing in the shop. Added a little starting fluid and some choke and the F40 fired up quickly.
Still doesnt seem to be charging at all when reved up, when checking on the battery terminals. I had replaced the alternator but fuel leaked into it, which may have not helped it? Also need to fiqure out how to check for alternator charging right at the alternator terminals to assure it is or is not working.
It moves and lifts:
Only yellow I had but the fuel tank is MUCH more secure:
 Chris and Cheryl
