190xt |
Post Reply | Page <12 |
Bobo Husker
Silver Level Joined: 28 Nov 2016 Location: Muscoda, WI Points: 96 |
Thanks drallis! I'm going to go with an a-pump. I got an oliver adjustable hub. So now to just get my pump gear machined for it.....and a pump. Lol still looking for one.
Bobo Husker
Also what do you guys use for heads on the 301? How much hp can you get through a stock (FVP went through it) head?
Orange Level Access Joined: 12 Sep 2009 Points: 19507 |
The large mounting hole in the engines front plate will either have to be oversized or have the nose of the injection pump machined smaller to fit the engine.
Bobo Husker
Got it. Thank you! Allis Chalmers around here are abit scarce so advice is hard to get.
As far as the Oliver adjustable hub ?? I use a hub and inj pump drive gear from a 7000-7010-7020-M2 combine.
Bobo Husker
Oh no kidding? So no machining needed on gear?
Edited by Bobo Husker - 06 Jan 2019 at 3:09am |
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4767 |
Using the right hub allows use of a stock gear from a 7000/7010/7020. I might be coaxed into selling the 12mm spare A pump I have.
bsallis180
Silver Level Joined: 29 Jul 2013 Location: Pennsylvania Points: 207 |
Part number #4023602
Bobo Husker
Thank guys! I came up with part#s,
74023602-gear 74061140-hub Sound right? Edited by Bobo Husker - 06 Jan 2019 at 11:28am |
bsallis180
If the numbers are off the parts book in my experience they put a 7 in front for some reason
Bobo Husker
Yup that's where I got them.
Thanks again! |
Bobo Husker
At what RPMs do reccomend going to a better dampner pully.
When you go to twin turbos and more than 800 HP you should consider a viscous damper. You should use a rubber type pulley, not a solid cast pulley like a 180/185/190. You should use one from an XT or 200, 7000, 7010, 7020, M2-3 combine. |
Bobo Husker
Got ya, that makes sense, but will a 7000 pully be ok for 3500+ RPMs? 4000 max.
Thanks! |
As long as it is in good (rubber) condition and shows no sign of movement.
Bobo Husker
DrAllis, thanks again!
Bobo Husker
What would you guys reccomend for a starting point for timing on an a pump on a 301?
bsallis180
32-36*
Bobo Husker
Thank you!
Larry W.
Silver Level Joined: 07 Nov 2010 Location: Luck, WI Points: 278 |
Bobo, check your mail, sent you a message.
Bobo Husker
Got it, thank you.
