Orchard M crawler fenders?
Dave Everett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Everett Quote  Post ReplyReply Direct Link To This Post Topic: Orchard M crawler fenders?
    Posted: 29 May 2010 at 5:41am
What would be the chances of finding a pair of these items?
I may have a chance to buy a complete tractor with the fenders missing.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2010 at 7:23am
HENs TEETH !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Everett Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2010 at 8:25am
Oh Fred PLEASE cheer me up.....!!!!!
Besides i do have geese.......will their teeth fit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Everett Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 3:10am
Dont look too promising does it?
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 7:06am
Anyone have a picture of them?
Dusty
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 7:15am
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 9:52am
How about getting some made?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 10:04am
Thats why I asked for a picture, but I can't make compound curves, flat curves I can make.
Dusty
ew View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ew Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 12:08pm
this is what was left of mine. also found this online.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 12:36pm
Thanks for the pictures. It would be a huge challenge to make them.
Dusty
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 5:44pm
Dave !!  I had  a nice set  like you  want  on a cat 15 orchard, it  has  been a few  years ago   they were  made in California.
  I remember a  brass tag with manufacturer  name.                               To  bad they went  with crawler.  I can ask around this part of  the  world for  a  set  for you.      Tony
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2010 at 7:36am
Tony, what about Dean? He does a heck of a job on hoods, I bet he could make up a set if he had a set he could borrow? Glenn
Armand(AZ) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Armand(AZ) Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2010 at 8:52am
Dave, when I built the model of the M that Lonnie posted (thanks Lonnie!!) I took measurements off a real machine.  To make the radius I used 1/4 inch soft copper tubing and bent it into the shape of the fender.  Then I quartered it the long way which gave me the two top sections (left and right) for the radius.  Then I soldered flat brass sheet for the top and side of the fenders.  The toughest part was making the opposite side to match!!  Maybe a similar approach would work for making a real set if you could find a thin wall 4 inch conduit or pipe that could be bent to the correct shape.  Then cut it and shape and weld sheet metal to the top and sides.
Sounds like a real task but I bet it could be done.      HTH   Armand
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2010 at 9:01am
This was my first thought exactly!  It would be a ton of work though.
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2010 at 12:53pm
Armand, do you still have your notes/measurements from the real machine?
Dusty
