Wd advice |
Page 12> |
what66 ![]() Silver Level ![]() ![]() Joined: 03 Sep 2013 Location: linden,ia Points: 167 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Jan 2016 at 11:22am |
Hi guys I'm looking to buy my second tractor I'm looking at a allis Wd.
http://ottumwa.craigslist.org/grd/5416445804.htm Is this a good price? Any help would be great thanks. |
While it's a little ugly it says runs and drives. Tires appear round. I've always maintained that a running working tractor is worth at least a thousand dollars. For five hundered I think your getting a deal. Give it a tune up chasing all the fluids and use it till your comfortable with the condition before investing in paint or upgrades.
CAn't tell much from one picture. It could be a bargain if everything works as it should and the rear rims aren't rusted out, but it could be a money pit too if sompin isn't right and you start fixinn things as you go.
If it runs and you can drive it to test the hand clutch and all the gears then the price is good. Also the curved shifter may indicate that this is a WD45 which gives it more power than just the WD. If it can't be started then you must assume nothing works and I would not give more than $200-300 for it. Good luck.
1957 WD45 dad's first AC
PatrickBeth ![]() Silver Level ![]() ![]() Joined: 04 Oct 2015 Location: Wisconsin Points: 184 |
If your in it for a challenge! Buy it! If it runs and moves go for it! Then get the check book out! Headlights, figure the fenders are rotten where they attach, all the oils are shot and will need to be flushed out a few times. Hope the block isn't cracked... But can always part out and recoup 500 bucks! Ask about implements looks like an old AC farm! May score big! Good luck, I'm enjoying the heck out of my WD project!
FloydKS ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: S E Kansas Points: 8421 |
even the one behind it has a can on the exhaust, so if they care enough to do that, there is some hope...
JakeWI ![]() Bronze Level ![]() Joined: 04 Jan 2016 Location: Southern WI Points: 12 |
Says it runs and drives ,sheetmetal looks not to bad I would go for it at that price.
Thanks for the advice I'll let you know what the guy says.
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8534 |
The price is not toooooo bad. Assuming the tires are ok as is. I paid almost that much for a WD with stuck engine. Just depends how bad you want it? Might be a 45 which is a little more desirable. More pictures would help too.
Regards, Chris |
Dmpaul89 ![]() Orange Level ![]() ![]() Joined: 06 Mar 2013 Location: Edwardsville,IL Points: 1689 |
Check the oil make sure no antifreeze in it.
Rick143 ![]() Orange Level ![]() ![]() Joined: 13 Dec 2015 Location: Lomira, WI Points: 247 |
Pull the dipstick if the bottom is rusty that means it's been sitting with water in the oil pan.
Thanks guys still waiting to hear back.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5037 |
If the rear rims are both good, you can't go wrong for $500. The rear rims alone are worth half the asking price.
Well I missed out on that one it's sold.
![]() There is another one here. http://desmoines.craigslist.org/grd/5421389659.html The only thing I'm worried a bought is that tire. |
It looks like it will need tires all the way around.
This one has potential. Yes you will need some tires.
Again about what I paid for one and it didn't run and had bad tires too. So even if they gave it to you you could put $2000 into it pretty easy. Good luck. Regards, Chris |
Kind of hard not to go for it for $500. I'd still offer 4 and see what happens. Or even start off with $300 saying the tires, fenders, lights, lift arm latches....anything else that is bad/missing. MAKE SURE it runs though... Have HIM start it for you.
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4102 |
If you buy it, it will keep me from buying it. I really don't need another project!
I got a hold of the guy I'm going to talk to him tonight after work wish me good luck.
I called on it It's a wd45 some where in the fifty's.
It dies burn some oil Ill check it before I buy it. I'm going on Sunday but he said a lot of people have called so it I might not get it after all. |
Good luck,
Not sure that left tire is going to be able to be saved? Some folks may shy away for that reason. Calls don't buy the item. Parts are readily available for the 45. I have seen worse. Regards, Chris |
grinder220 ![]() Orange Level ![]() Joined: 11 Jan 2012 Location: Clinton Iowa Points: 2372 |
Almost anybody selling something will say they've had lots of calls and lots of people interested in whatever it is they have but yet there it is still for sale.
Tomorrow I'm going to check it out I'll let you know what happens.
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 12007 |
A WD45 for $500 bucks and it runs? Don't dilly-dally. I think that's a pretty good price even if it may need tires. If yer' lookin' for a neat project Tractor, there it is! Stick some air in the tire and get it up on a Trailer and git' it home! Good luck!
allischalmerguy ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Deep River, IA Points: 2893 |
My advice...Just make sure it will run for a while...not just for a few seconds and that is has some power and it doesn't smoke !!! I bought a tractor once,...it did not run too good,, the seller said "it just needs some carb cleaner and it will run ok"""" I believed him..what I should of said was if that is all it needs why didn't you do that before I came and got it running right! Learned a lesson there!
David there are better ones around here, unless you are desperate for one, don't be in a hurry. Pick up The Exchange, local shopper that goes over the bottom 1/2 of Iowa and a lot of Missouri. More of them in there are being sold by retired farmers or the widows or sons and daughters that don't have a need for dads old tractor. . Most of them would have been taken care of in their working days, as the owners dependaded on them to make a living.
I got it!!!
![]() It runs fine just needs a tune up and a little maintenance. It's a wd45 it's 1955 I think. I'll post some pic's later. |
Congratulations! Looking forward to the pictures too! Running tractor! Awesome.
Regards, Chris |
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8455 |
Congratulations!!! Looks pretty good I think!
![]() ![]() Edited by what66 - 31 Jan 2016 at 4:45pm |
Page 12> |
