Pics combining soybeans Tuesday |
Page 12> |
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Oct 2015 at 7:12am |
My AHHC wasn't working right for the first couple rounds so the beans weren't getting cut like I thought they should. You can see the stubble is high in some spots. I somehow "fixed" the problem. Took panels off looking for mouse nibblings, switched coils, etc etc but didn't find much of anything then tried the 6th fuse and that one didn't blow so away I went. I hate having a known unresolved problem looming over my head. Later I'm going to pull the whole harness out of the cab and give it a good going over but right now everything, including every sensor/monitor is working as it should be.
![]() ![]() Edited by Lonn - 08 Oct 2015 at 7:20am |
Wink I am a Russian Bot |
tornado8070 ![]() Orange Level ![]() Joined: 24 Mar 2013 Location: MI Points: 1341 |
Looking good. I'm waiting for more XT pics on the chisel. 😊
09’ DT205B, 08’ DT220A, 83' 8070 MFWD, 83’ 8070 85’ 8050 MFWD, 83' 8030, 82' 8010, 85’ 6080 MFWD, 84’ 6080, 79' 7020, 85' M3 RWD, 85' 920 diesel,AC C-50 forklift.
Hoping to have video of the XT and maybe the 7030 or 50 within a week or so.
SHAMELESS ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
what? to good to just use yer right arm to adjust the header??? I haven't used the auto height since our old 404, and that was umpteen combines ago! I can gits right down where the sickle jiggles the clods on the ground!
Steve Bright ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Martinsville, I Points: 2107 |
Would love to own and L2 that looks that nice, great pictures
ooops...I meant 403!
Who's counting Shameless
And the problem is I'm not too good so I has to let the combine do it for me
actually every time I lifted or lowered the header at the end rows the fuse would blow, the automatics just wouldn't work properly but not blow the fuse. whatever, it works now Edited by Lonn - 08 Oct 2015 at 9:22am |
aras ![]() Orange Level ![]() Joined: 28 Jul 2011 Location: Weston, WI Points: 665 |
That is one nice combine!
btred1466 ![]() Silver Level ![]() Joined: 12 Jul 2012 Location: Magnolia, OHIO Points: 205 |
Looking forward to any XT or 7030 or 7050 videos.
Amos ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ontario Points: 1318 |
Look inside your hydrostat handle. I had both the L2 and L3 do the same intermittent fuse blowing and that is where I found the problem on both
Did that. I found a dried up long dead mouse in there and a bare wire where it had been rubbing on a metal edge but it still blew fuses after fixing that then I got the magic wand out and walla it started to work.
yeah...that would suck....just teasing ya!
matador ![]() Orange Level ![]() ![]() Joined: 10 Nov 2014 Location: Wyoming Points: 1727 |
Dual fuel tanks? I'm going to look like the Gleaner novice I am, but I hope that's overkill!
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8455 |
That's a great lookin combine! Looks a heckava lot like another late model L2 Corn Plus I've seen before! Including the flex header! Lol
Shameless, I know you were teasing. I used to not think twice about manually raising and lowering the header and watching close so as to not push dirt with the old E. It is kinda nice not to be watching so intensely. It'd be ever better if I'd gotten all the stones picked this year. BTW after about 70 acres of cutting with plenty of stones I haven't broken a sickle section. That was always a problem before I put the SCH cut system on.
Great looking Gleaner!!
1957 WD45 dad's first AC
Thanks fellas
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8516 |
Awesome looking combine! Thanks for posting. I can almost hear it humming along.
Regards, Chris |
JimIA ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Castalia Iowa Points: 1983 |
Great pictures! Good to see Chris' old machine still running and looking good!
Edited by JimIA - 09 Oct 2015 at 9:13am |
Brian F(IL) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Paxton, IL Points: 2717 |
I've never seen dual fuel tanks before either. Learn something new every day!
Nice looking machine, Lonn. I remember cleaning all the windows in one of those when they were brand new before it left our dealership. |
critter ![]() Silver Level Access ![]() Joined: 13 Nov 2013 Location: Ohio Points: 254 |
Is there any extra bracing with the second tank? Ever have any cracking on the back with the extra weight? Been thinking of putting a second tank on our L3 but wondered if the back end would handle the extra weight ok.
wekracer ![]() Orange Level ![]() ![]() Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1590 |
We have a second tank on our L2. I got over 100 acres on about 150 gallons. I was also fighting the auto header fuse blowing and this year found that when I raised the head the wire harness would rub the cylinder drive ideler pulley and short. You might check there too. I am also running SCH and I don't think I've replaced a section in 2 years. But we only run about 125 acres a year.
Not bad on fuel. I have dual tanks on the Ford, because they're needed. If both tanks drained quickly, that wouldn't be cheap!
Looks like a sharp setup!
I was replacing 10-sections a day or better until I found out the header teeth were taking them out setting down to low. now when combining I raise the reel up a bit and no more problems! whew!
Lonn,
Did you have any Videos of your XT and 7030 and 7050?
Unfortunately I didn't get any pics or video of tillage work this fall. Everything seemed so busy and hectic between work and farm. I didn't use the 190 at all this fall either. Just the 30 and 50.
Yes the same here. I will be finishing today as I work in the lagoon manure. Talking 8" of snow tonight though tomorrow. I'm hoping the spring will allow me time for some video.
Lonn,
Do you any pictures of your One Ninety XT 7030 and 7050?
Page 12> |
