Winch options for a HD5
serioussam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote serioussam Quote  Post ReplyReply Direct Link To This Post Topic: Winch options for a HD5
    Posted: 30 Aug 2015 at 7:51am
Looking at getting a winch for the HD5 and would like to know what my options are
Thanks for any input
gemdozer View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2015 at 2:53pm
The hd5 and hd6  and td9 used the same winch model
Post Options Post Options   Thanks (1) Thanks(1)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2015 at 2:58pm
One problem is they are driven by output shaft on transmission - and if you have loader that means counterweights would block access .
 One option might be to go to unit with a hydraulic motor .
Also as winch is transmission driven - it would mean clutch engagement when winch is used .
donoman View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote donoman Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2015 at 3:09pm
your best option for a HD5 would be a Carco E24 or EA an Issacson WO6-9 is similar to the EA and was also fitted to TD6 and TD9'S
Post Options Post Options   Thanks (0) Thanks(0)   Quote serioussam Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2015 at 8:52pm
I might be getting a winch off a TD9 , also what else am I going to need to make this thing work on the hd5
Thanks again for all the help
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2015 at 11:30pm
 If I recall correctly, Allis has a  different drive shaft to IH. There is a slight difference in the mounting stud pattern between the two makes of tractor. Ive used Carco from IH tractors on HD6
Post Options Post Options   Thanks (0) Thanks(0)   Quote donoman Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2015 at 2:05am
I fitted a WO 6-9 Issacson to the Buda HD6E I purchased in 1974 ,it bolted straight up, I think there is a difference in driveshaft length, although the splines are the same, I recently acquired a E 3O Carco winch believed to be off a TD9 I had to lengthen the shaft to make it  the correct length.
This page was generated in 0.206 seconds.
