straight pipe inlet o.d.?
mufflerboltz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mufflerboltz Quote  Post ReplyReply Direct Link To This Post Topic: straight pipe inlet o.d.?
    Posted: 05 Sep 2013 at 10:01pm
Making a straight pipe for a friends wd45 and do not have a muffler or manifold close by to measure to find out the out side diameter of the inlet pipe that inserts into the manifold, so if anyone could help me out with the size would be greatly appreciated! Thanks.
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2013 at 5:08am
I made mine out of thin wall stainless tubing  I used 3" it went over the outside of the manifold i bored out the manifold so it would breath i welded a strap on it and bolted it to the hole in the  manifold
Post Options Post Options   Thanks (0) Thanks(0)   Quote mufflerboltz Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2013 at 6:21am
i need to make this so he can change it back to a muffler if he wants to. I know the easiest way to do it would be to hack the bottom side of a muffler off and stick a chrome pipe on it and weld away but i have a crap load of exhaust pipe at work that is cheaper and easier for access then going to buy a muffler to cut up.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2013 at 8:22am
 should be 1 5/8" inlet
If possible make a drip edge for it so water won't run in the manifold
Edited by Charlie175 - 06 Sep 2013 at 8:23am
Charlie
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2013 at 5:08am
Allis Muffler is #70229531.
Here is a link to 'aftermarket' muffler AC-4.
It's I/D shows as 1 5/8", O/D "could be" 1 3/4"
Gary
http://www.tractorsupply.com/en/store/muffler-aliss-chalmers-mfg-ac-4
PS note the aliss LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote mufflerboltz Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2013 at 6:55am
thanks Gary, I tried to research it but all I get in the I.D. of 1 5/8''. I have a muffler to go off of now so I'll just take that to the shop and make it all according to the measurements of the muffler.
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2013 at 9:45am
I just measured some manifolds I have for parts, 1.75" is the bore size of the manifold outlet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mufflerboltz Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2013 at 6:38pm
yup ended up using 1.75 pipe that i bell flared and the bendix bender and then weld a 18'' long by 3'' wide exhaust tip, after that i took a 4'' section of 3'' pipe and expanded on end to 3.5'' and welded that to the bottom end of the tip for the clamp to bite against. Turned out nice and bolted on solid, kinda of thinking of making a few to sell.
This page was generated in 0.244 seconds.
