Allis Chalmers "One Sixty"
waylon73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote waylon73 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers "One Sixty"
    Posted: 02 Aug 2012 at 11:16am
Can anyone tell me what year model tractor i have based on its serial number which is 141570? "One Sixty" is spelled out on the serial number plate. Also is there any other place i can get reliable information on this tractor?
thanks you,
 Waylon
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2012 at 11:32am
I dont think so.....The 160 was an imported from Renult.....and dates and serial numbers were not recorded.
1968 D15D,1962 D19D
OrangePowerGA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangePowerGA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2012 at 5:09pm
It was an imported tractor.  The good thing is that it has a Perkins engine.
It appears that the serial numbers were not recorded.
One-Sixty --- 1969-1971----4,110
160-----------1972-1973----587
6040----------1974----------499
The 6040 was built in 1974, it was a 160 with updated sheetmetal to match the 7000 series.
AC - WD
JD - 650
PlayGun View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PlayGun Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2012 at 6:14pm
think it might be a 70 model because of the last 2 digits then? It's possible it was that simple???
Hopefully Future AC Man! Ride With Jesus my friends!     Lonas
JarrodACFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JarrodACFan Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2012 at 7:11pm
These are production numbers, not serials, correct?
1956 WD45 Narrow Front Factory Power Steering, 1953 WD Wide Front
Allis Express in Muncie, IN
Post Options Post Options   Thanks (0) Thanks(0)   Quote PlayGun Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2012 at 7:19pm
I would heavily assume he posted production numbers, but assumptions are like ____ lol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PlayGun Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2012 at 7:20pm
This will tell you quite a bit about your tractor. hope it helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangePowerGA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2012 at 9:52pm
Correct.
AC - WD
JD - 650
Flyer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flyer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2012 at 9:30pm
Mine is serial no. 140996 and was purchased new by my uncle in July of 1970.
An optimist sees the glass as half full. The pessimist sees the glass as half empty. The engineer sees a glass with double the required capacity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waylon73 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2012 at 8:43pm
Thank you every one for all your help. I have yet to find a year model but everything i have replaced so far minus filters have been from france. I found and operators manual for it on ebay printed in 1970. It shows my engine serial numbers located on the left side above the injection pump but mine are actualy on the right side next to the fuel lift pump. and it showed a serial data plate on the left side but mine is located on the right. other than that every thing else has been the same. But on a good note I have finaly got it up and running today. i had to replace the starter, fuel lift pump, and had the fuel injection pump and injectors rebuilt. Plus the standard tune up stuff like put a new batery, changed the oil and cooling system fluid and of course filters. next is the hydrolic/trans fluid.
