D17 power steerinf front support |
pied ![]() Bronze Level ![]() Joined: 26 Mar 2012 Location: Southeast, LA. Points: 8 |
![]() ![]() ![]() ![]() ![]() Posted: 26 Mar 2012 at 2:30pm |
Has anyone ever rebuilt the power steering front support on a D17? something gave up in the front support and I was wondering if I should attempt to rebuild it myself.
RichinWis ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Deforest Wis Points: 691 |
Basically the ram side is just like a hydraulic ram with a gear rack on the right side and a hydraulic motor on the other side. Not real complicated in my opinion. The hard part is getting at it on the tractor, as it is all contained in the front casting.
That's what I was wondering. Seems like it would be a pain. Any tips are recomendations to help me along. I ordered a service manual and hope it has clear details on this. THANKS for any help you can give.
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
once removed it is pretty easy to work on. It's heavy though, get help
Charlie
Don(MO) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
I'm betting it's the pin in the rack to piston. You can fix it without removing the hole unit.
Also if you do tear it apart, you will need new vellum gaskets/spacers.
Charlie
I had problems on the photo upload but that is the tractor with the steering problem. It became mine when my son died in a hunting accident. I have had no experiences with tractors till now and I am appreciating all of the information everyone is giving. I'm trying to get it into shape and will keep it in memory of Jason. In the background is the other tractor, a Ford 3000. I know very little about it also but will tackle that project after this one. It's good to know that I have people out there that know everything about tractors! THANKS!!!!!
jacelee ![]() Bronze Level ![]() Joined: 01 Apr 2012 Location: South LA. Points: 6 |
Well, I attempted the front support removal yasterday. everything went well. I came across the problem while disassembling. Now I need to know if anyone knows where I can find this and what is it called. It connects to the spline shaft on the bottom of the front support and hooks to the tie rods. No part number on it.
You can view the AGCO parts books as a "guest". I'm pretty sure www.agcopartsbooks.com is the web address. You can see expanded views of all parts of the tractor. Talking to Sandy Lake Imp (one of the sponsors here) will help too. They will be able to set you up with just about any part you will need.
orangereborn ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: NW WI Points: 1478 |
Is it the part that has the splines in it and the two holes for the tie rods and fits over the
splined shaft that comes out of the front support? Steering arm #70250639. Old parts books show 229062. Did it break or are the splines gone? I have a couple of parts tractors that should have one. Out checking.....Dale
Orangereborn 964 192nd Ave New Richmond, WI 54017 715-247-3079 715-781-2055 |
Thanks for that info!!!!! I'll check out that number!! That's the part I'm speeking of and it 's broken not stripped out. The spline on the front support seems to be fine. Let me know if you fine one. Has anyone ever have this problem or is it rare to have that happen?
Dale, I located the part with the number you gave me 229062 but they are OUT OF STOCK! What luck! Were you able to check your supply? Please let me know either way! And THANKS for being soooo helpful.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21854 |
I'll bet I could weld it back together......been there....dun that.
You think welding it woulr hold up?
I'm not there looking at it, but it's pretty simple.....if it doesn't hold up, what are you out???? you'll still need to get a different one. I can't imagine not being able to weld it I guess, off the tractor, (not on the tractor) where you can clean it and roll it around to weld it good.
Think it would mess up the spline ?
DonDittmar ![]() Orange Level ![]() ![]() Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2516 |
Like the DR says, if it does mess it up what are your out?
I would agree with the experts on this one. I'd try the weld. Word is a new one over
$600 and used $200 plus.......Dale
We'll give it a shot and let ya'll know how it turns out!
