Tractors Sounds I Like |
  Page 12> |
   Farrell(Utah)
   Joined: 11 Sep 2009 Location: Springville, Ut Points: 558  |
      Quote   Reply
     Topic: Tractors Sounds I LikePosted: 29 Jan 2012 at 7:27pm  |
   Don(M0)'s comment about the "bark" of his WD45 under load while plowing brought back memories.  I love the sound of a WD45 with a Nelson muffler plowing and working away.  The sound is snappy and seems to say "let's go to work".  Another that I like is the M Farmall when they are working.  A different sound but still distinctive.
     A(1937), 2 G,  2 WD45 diesels, 6 WD45 gas, UC, 2 WD,  D17 gas, WF, Farmall 400, D12, Kubota B3030
   Don(MI)
   Joined: 15 Sep 2009 Location: Michigan Points: 3900  |
      Quote   Reply
     Posted: 29 Jan 2012 at 7:35pm |
   Funny you say this, just thinking this afternoon after getting the G going again, that its engine sure has a distinctive sound. And that 10 HP engine snaps when hitting the throttle! Purrs at an idle too!
     Galatians 5:22-24
  "I got a pig at home in a pen and corn to feed him on, All I need is a pretty little girl to feed him when I'm gone!"  |
   AaronSEIA
   Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2573  |
      Quote   Reply
     Posted: 29 Jan 2012 at 7:53pm |
   Dad's 7060 has an 8050 in it and a custom exhaust.  That thing sounds sweet going through the PS.  My WC with the straight pipe sounds fantastic when the gov hits.  And then there is McKims pulling tractor, Power Maxx.  180 with a 301 and twin turbo's making about 80 lbs of boost.  Dang it, now I've got the urge to see a pull.
  AaronSEIA
   JOHN N/IL
      Quote   Reply
     Posted: 29 Jan 2012 at 7:55pm |
   Talking about nelson mufflers,i put a new muffler on my 17iv and it sounds wimpy.Where can i get a nelson for a series iv.Thanks John
   Bolivar Boy
   Joined: 27 Dec 2011 Location: wooster, ohio Points: 641  |
      Quote   Reply
     Posted: 29 Jan 2012 at 8:07pm |
   i remember the sounds of two tractors working in the same field performing the same task like plowing or working ground but doing it at slightly different rpm. the rpm variance would drive me nuts. likewise ,at night running full throttle gassers and seeing the muffler glow red or that one inch of fire shooting out the top of the muffler on a 17 diesel under full load. loved seeing the little bullet red tail lights telling everyone where you were.
   rrhead(SD)
   Joined: 11 Sep 2009 Location: Canton, SD Points: 432  |
      Quote   Reply
     Posted: 29 Jan 2012 at 8:11pm |
   acwdwcman
   Joined: 16 Oct 2010 Location: palmyra, il Points: 1075  |
      Quote   Reply
     Posted: 29 Jan 2012 at 8:14pm |
   i love the sound of an unstyled wc.. it really barks at ya.
  the farmall m is a very famillliar sound.its kinda deep. hear an m when splitting wood at work..
     wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd.  allis chalmers snap coupler blade and 3 bottom snap coupler plow
   Russ-neia
      Quote   Reply
     Posted: 29 Jan 2012 at 8:21pm |
   John, last I knew you could still get the Series IV oval nelson with the offset outlet from AGCO.  Problem is the price - $340 is what I remember.  I can look up the receipt for certain but I felt it was worth the original sound for a restoration.
     The innovators offer what others will imitate.
   Farrell(Utah)
      Quote   Reply
     Posted: 29 Jan 2012 at 8:26pm |
   Yes, you have got to like the 6 cylinder Buda sound.  I have two D17 diesels with offmarket mufflers.  They simply don't sound like the Nelsons.  I also would like to know where you can get the Nelsons.
   JW in MO
   Joined: 16 Feb 2010 Location: South KC Area Points: 2671  |
      Quote   Reply
     Posted: 29 Jan 2012 at 8:51pm |
 I agree, a few years ago I took the 37 WC to a plow day,  I worked several days adjusting the distributor and carburator and she sure sounded fiesty when we hit a clay patch.  Not the deep sound of the big boys but sure is a sweet sound.
   AllisFreak MN
   Joined: 07 Dec 2009 Location: Minnesota Points: 1590  |
      Quote   Reply
     Posted: 29 Jan 2012 at 8:57pm |
   Don(MI)
      Quote   Reply
     Posted: 29 Jan 2012 at 9:14pm |
   The G
  [TUBE]vLOR61BZOvM&feature=mfu_in_order&list=UL[/TUBE]
WC
[TUBE]xDbOfZmoaqw[/TUBE]
     Galatians 5:22-24
   JOHN N/IL
      Quote   Reply
     Posted: 29 Jan 2012 at 9:29pm |
   At the end of feb, agco is having there spring sale im going to  price a nelson for my iv,and see how much it will cost ,might be worth it if lasts twenty years.A while ago someone said the mufflers from walker sound like the nelsons.All i know is that the one i got aftermarket sounds weak,not like my dads original 17ivgas.I;ll keep looking and if i find something i"ll post about it.
   Kip-Utah
   Joined: 14 Sep 2009 Location: Southern Utah Points: 918  |
      Quote   Reply
     Posted: 29 Jan 2012 at 10:08pm |
   To me an angle exhaust WC with the standard unmuffled pinched pipe running up against the governor under a load just sounds like a real tractor to me. I also like my little 125 cubic incher in my C pulling tractor barking through  a straight pipe working hard on pulling sled! Kip
     HANSEN'S OLD ORANGE IRON. Showing, Pulling, & Going!!
   Unit3
   Joined: 17 Oct 2009 Location: NC Iowa Points: 5605  |
      Quote   Reply
     Posted: 29 Jan 2012 at 10:50pm |
The deep rich throatty bass of a UC. I still remember her as she come to life for the first time in 12 years in our shed. I can hear an Allis Chalmers 426 coming down the road. I can tell it from other brands. Great question. I love to see the pictures of different AC's, but this is a great question.
   smokey
   Joined: 04 Oct 2010 Location: Michigan Points: 287  |
      Quote   Reply
     Posted: 30 Jan 2012 at 6:40am |
   My 1936 WC with pinch pipe sounds like its ready to go to work, but I've never worked it just putts around with it, then the 1953 CA with crome straight pipe w/ 2-14s on it plowing will keep ya awake, my fav is 1971 190xt crome pipe at 1200 rpm's turbo just starting to come to life with a whistle , I think its why I cant hear today "WHAT" !
   DougG
      Quote   Reply
     Posted: 30 Jan 2012 at 7:33am |
   Love the sound of a turned up 301 in a 180 tractor ; the uneven idle, the little puffs of smoke - dang I,m gonna go fire it up now !!
   Don(MI)
      Quote   Reply
     Posted: 30 Jan 2012 at 7:36am |
   Also, really like the sound of grandpas D-17, at a low, low idle. Hearing that raincap 'ding, ding, ding' on the top of the muffler, just sounds good!
     Galatians 5:22-24
   DonDittmar
   Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2516  |
      Quote   Reply
     Posted: 30 Jan 2012 at 7:48am |
   I like the BUDA 6 sounds, I like the "peppy" sound of my IH Cub Lo-Boy, and now don't shoot me for this one, but I like the sounds of a JD 2 Cyl Diesel
  1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start  |
   XT in pa
   Joined: 21 Apr 2011 Location: hickory pa Points: 711  |
      Quote   Reply
     Posted: 30 Jan 2012 at 9:31am |
   my 7045 with a stright 4 1/2 pipe plowing sounds awesome
     190XT,D17and 7045
   Rick of HopeIN
   Joined: 11 Sep 2009 Location: Hope, Indiana Points: 1329  |
      Quote   Reply
     Posted: 30 Jan 2012 at 8:00pm |
i was able to buy a Nelson muffler for my B and D14  from a Cummins distributor.  The old Nelson catalog number was stll good.  Price was less than half of Agco quote.
  Edited by Rick of HopeIN - 30 Jan 2012 at 8:09pm  |
   Alberta Phil
   Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3938  |
      Quote   Reply
     Posted: 30 Jan 2012 at 8:26pm |
   My favorite would have to be a 20-35 hard at work with that 461 cu. inches barking through a straight stack!!  Music to my ears!!
   CBL95
   Joined: 18 Apr 2011 Location: Winslow, IN Points: 130  |
      Quote   Reply
     Posted: 30 Jan 2012 at 8:35pm |
XT in PA,
 I second that! about ten years old running a 13 foot chisel on dads 7045ps going through the gears at night.   he also had a 4 12 in straight pipe on it, and in a couple of fields in the bottoms you could hear that one and many other tractors blarring out for miles.     sad day when it left for kentucky:(
  Edited by CBL95 - 30 Jan 2012 at 8:36pm  |
   cornbinder
   Joined: 26 Sep 2011 Location: jeromesville,oh Points: 846  |
      Quote   Reply
     Posted: 30 Jan 2012 at 9:54pm |
 gee i wonder where you ever saw a flame coming out the muffler of a d-17d? sounds like something some kid would do while plowing or working ground at night while dad wasn't looking. he-he those 262 buda's have a sweet sound all of their own.
   Larry(OH)
   Joined: 11 Sep 2009 Location: Shreve Ohio Points: 1580  |
      Quote   Reply
     Posted: 31 Jan 2012 at 5:21am |
   My WC puller @ 5000 rpm
     '40 WC puller, '65 770 Ollie
  *ALLIS EXPRESS contact* I can explain it to you, BUT I cannot understand it for you!!  |
   Calvin Schmidt
   Joined: 11 Sep 2009 Location: Ontario Can. Points: 4555  |
      Quote   Reply
     Posted: 31 Jan 2012 at 5:43am |
    I have a few favourite sounds. It's hard to beat the sound of a WD-45 talking trough a Nelson muffler. Love the sound of my D-21 (5" pipe)pulling 25' of cultivator , my D-17 IV diesel cultivating beans, and my D-15 II and D-12 III mowing grass.  |
   Eddie(IL)
   Joined: 25 Apr 2010 Location: Oakwood, IL Points: 385  |
      Quote   Reply
     Posted: 31 Jan 2012 at 6:29am |
        I've been fortunate enough to have been able to drive nearly every model Allis made, and there hasn't been one I haven't enjoyed operating yet...but hands down, my vote has to go with a 19 diesel!!
   cornbinder
      Quote   Reply
     Posted: 31 Jan 2012 at 6:52am |
    i'll second that motion. a 262 with a whistle, NICE!!!  |
   Don(MI)
      Quote   Reply
     Posted: 31 Jan 2012 at 7:29am |
   http://www.youtube.com/watch?v=F-QTZQG_b7Y
  Yes, the whistle is cool. Gramps and uncle let me hook up to the chopper last fall, dad shot this video. There is nothing quite like the turbo on a D-19.
     Galatians 5:22-24
   HagerAC
      Quote   Reply
     Posted: 31 Jan 2012 at 9:06am |
I really like the sound of my 180 with the OEM muffler on it, just a distinct sound.  Also got a curved 3 inch chrome stack on it when I want to make some noise.  Also really like the sound of a 262 diesel.
  Page 12> |
| Forum Jump | Forum Permissions  ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum  |
