WD seat shock
Terry GA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terry GA Quote  Post ReplyReply Direct Link To This Post Topic: WD seat shock
    Posted: 18 Aug 2011 at 10:40am
Does anyone know if there is a cross over shock and spring for a WD seat?Like a Monroe etc made for a car or truck but will fit a WD.If so part number if possible,thanks,
Terry.
I couldn't repair your brakes, so I made your horn louder.
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2011 at 10:53am
I replaced the shock on a WD with one off a 1951 Ford car. It worked good and fit the spring. I dont know what number it was, as that was 50 years ago.
WD in kansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD in kansas Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2011 at 12:06pm
I went through this a few months ago. Even with a very good NAPA man (oldtimer) we could not find any that were the correct length and that also had the correct "eye" size to accept the rubber bushings. A couple of the vendors on this site have new replacements, but they are a bit pricey. I found a used one from a member here, and bought new bushings for it.
1950 WD, Duetz Allis 613
George R. (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote George R. (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2011 at 12:37pm
Give Tony Carbaugh a call at 877-602-3994.  He will be able to help you out.  Good folks to do business with.  Tony is also a sponsor of this site.  You can check out his catalog at his website shown on the parts pages.
My tractor is not leaking oil, it's just marking it's territory!
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2011 at 4:39pm
 Hi  guys ! We  went  all through this years ago ,  got  set up to make  the  schocks work, welded  thick washers  to them, were ready go, then  supplier  made them  ready to bolt  on.  Give  us a shout.   or  email.    1-877-602-3994     tony@tonystractor.com
Thanks  Tony
NCAllisnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2011 at 8:48pm
I used these parts a few years ago.  Don't let them cross the monroe # to another brand, the Monroe 5752 is the same dimensions.
Monroe 5752 - Advance Auto - $25
Seat Bushings - HELP! 31001 - $7
Things may have changed, I bought these part numbers in 2008 or 2009.
Adam
