6080
bluechev View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bluechev Quote  Post ReplyReply Direct Link To This Post Topic: 6080
    Posted: 22 Jul 2026 at 2:27pm
Have 6080 with Knock in engine doesnt appear to be any shrapnel in oil or pan runs ok
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 3:15pm
The question is are you willing to chance putting a rod though the block or continuing to ruin a crankshaft? It could just be piston skirt slapping a little. Need to find the source of the knock.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 5:07pm
No miss-fire or white exhaust smoke?? How many HOURS ?? They don't have rod bearing problems but one could still fail.  How much crankshaft end play is there ??  A failed rod bearing should be noisiest at start up and maybe quiet down a little when oil pressure hits it. A really failed rod bearing will have the crankshaft journal probably ruined. Turbo diesel engine cranks are very hard and a failed burned out bearing takes the hardness away., making the crank junk. You talk like you have the oil pan off ??
Edited by DrAllis - 22 Jul 2026 at 9:47pm
