HD6 final drive bearings
retired operator View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote retired operator Quote  Post ReplyReply Direct Link To This Post Topic: HD6 final drive bearings
    Posted: 18 Apr 2026 at 9:51am
Good morning all
new to the forum and have a question
I have a HD6 that I need final drive bearings for.
I have the parts book and am working to match modern bearing to the machine'
Question is this. Any one cross referenced bearings from the book to modern bearings?
Sorry if this has be addressed before I havent taken the time to go through all of the posts. The machine runs strong just needs new bearings and seals on the out board side
I don't want to tear it down until i see if I can get parts
Thanks in advance
JIm
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2026 at 11:31am
I have for the outbore bearing the boot seal with spring assambly  and 2 ring seal and gone check for the outside bearing 080101.
Post Options Post Options   Thanks (0) Thanks(0)   Quote retired operator Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2026 at 3:34pm
fantisic let new know
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2026 at 9:46pm
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2026 at 9:23am
you would be able to cross bearings when torn apart, nothing special. i have a 6 parts machine with complete finals in KS if you might need something.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2026 at 1:46pm
That outboard bearing is no longer available unless you can find a NOS or used.
Here is another thread with excellent information.
Post Options Post Options   Thanks (1) Thanks(1)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2026 at 3:15pm
we found those big double sphericals from a large bearing warehouse for our series B  11.  had genuine and off brand available.  not the same bearing obvously, but there is a chance finding something.
Post Options Post Options   Thanks (0) Thanks(0)   Quote retired operator Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2026 at 10:49pm
Question is the transmisson complete?
Might be easier to just swap them out
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2026 at 5:37am
If you have to removed your transmission you better repair and swap for a other one maybe yours is better ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote retired operator Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2026 at 7:35pm
Cal(KS) could you pm me?
Thanks Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote retired operator Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2026 at 9:44pm
I finally dropped the cover on the inside of the sproket and found everything intact.
however the shaft spins freely which leads me to believe the shaft is broken or the splines are shot. from what i see the shaft will be the fun part to find. Also may need a sproket as it looks like the splines on the sprocket are worn out
I ll see what i come up with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2026 at 10:55am
Yikes! Cry
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2026 at 12:47pm
I have a used final that has all the parts inside. I guy just took the shaft out of the other side. Splines where all good. The sprocket was not bad for as bad as the tracks are.His shaft was broken.
But I am to crippled up with arthritis to take it off for you. The track had been removed from the other side by others. This side still has the track. So a all day job I would guess. In the Land of Fruits and Nuts (Calif).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2026 at 5:13pm
HD5 and HD6 use same rear castings and parts , 2 link longer track on 6
Outboard Link Belt bearing is the tough one as all other bearings in trans and finals are stock parts easy to obtain at bearing house
