D14 reverse gear NO WORK'EE,,,
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: D14 reverse gear NO WORK'EE,,,
    Posted: 09 Aug 2025 at 11:41pm
 I have not had a need to use my D14 in some time until yesterday and my Son could not get it to go into Reverse,,,,!!  He checked all the fluid levels and everything checked out but still  will not go into Reverse,,,,!!
 I checked out the gears when I did the total rebuilding, and all looked like new inside the housing. The transmission has never jumped out of gear and until now would slip into Reverse smooth as ,,,,,pie,,,
 Anyone got a clue what issue might be keeping it from going into reverse,,,,???
  Many thanks in advance,,,,!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2025 at 7:24am
The shift lever physically will not shift into reverse??? and you have actually used reverse gear in the recent past?? OR you've had the shift cover off and haven't used reverse until now ?? There are only two possibilities as per your description: #1. Your son needed to let up on the clutch a bit to get the gears to rotate and mesh...or #2. you didn't get the shift cover back on correctly. A broken shift fork should let the lever shift into reverse position but nothing...zero....zip....nadda.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2025 at 11:26pm
Hey Dr Allis....thanks for the comeback,,,,,I did have the cover off about 7 years ago only to check out the gears and inspect the shafts. All the gears looked like new with no play in the shafts to gears.
  This tractor was purchased new by US Forest Service as a backhoe/Loader and was in service all its life in the Sacramento Mountains in SE New Mexico.
  We had not had a need to use the tractor so it sat for about 7-8 months. When Jamie went to use it,,it would not go into reverse,,even after shutting off engine and trying to force the gearshift into the reverse slot ,,,,??
 It just will not go into reverse,,,,??
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2025 at 6:52pm
take the shift cover off and inspect..
This page was generated in 0.077 seconds.
