Snap-coupler lift latches LEFT/RIGHT |
Robert Musgrave
Silver Level Access
Joined: 11 Sep 2009 Location: SE Wisconsin Points: 241 |
Topic: Snap-coupler lift latches LEFT/RIGHTPosted: 16 Mar 2025 at 7:21pm |
checked my 1949 "WD" and they are correct.
Mikez
Posted: 16 Mar 2025 at 7:36am |
We have an early d17 and it has the bar across. My great uncle bought tractor brand new from my grandfather. That bar will raddle a little when lifting implements. When plowing you could tell when traction booster was working.
Posted: 16 Mar 2025 at 6:57am |
I have too. And it always seems they were bent inward, which could be caused by a lift latch on the wrong way AND an implements lifting link frozen and not able to twist ?? I'm sure I've never seen one bent outwards.
Edited by DrAllis - 16 Mar 2025 at 6:59am |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4144 |
Posted: 16 Mar 2025 at 6:03am |
I have seen bent lift arms and thought, how in the **** did you do that???
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3077 |
Posted: 15 Mar 2025 at 3:52pm |
Thanks Pat and Dr Allis. I would think it would take some serious abuse to break a lift arm. Thanks again
Posted: 15 Mar 2025 at 3:12pm |
It was a solid shaft. I believe even the last WD-45's had that as an option as did the early D-17's when they had a 4-bottom plow hanging on the back.
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4948 |
Posted: 15 Mar 2025 at 1:01pm |
We had a series 3 d17 with a pipe that went through the holes . The series 1 didn't have the pipe between them. I was told it beefed up the arms and were less likely to break one.
ACinSC
Posted: 15 Mar 2025 at 11:49am |
What's the purpose of the 1+1/4" ish hole underneath my lift latches? A pipe that something is mounted on? Thanks
IBWD MIke
Posted: 15 Mar 2025 at 9:19am |
Dennis, I might have a book for pin-hitch plows out in the shop, maybe. I do not have any plows that old. Have some 'hands' (have heard them called that) from implements from the pin-hitch era.
Dennis J OPKs
Joined: 12 Sep 2009 Location: Overland Park, Points: 553 |
Posted: 15 Mar 2025 at 8:55am |
Showing my age here as well as poor memory. The early pin hitch plows vintage 1948-2/16 had a sleeve type connection which slipped over the lift arm but was a permanent part of the plow. Here's where the memory gets foggy, those sleeves had right angle type bolt which preceded the set screw and could be turned in by hand. Seems like they were on the inside but wouldn't swear to it. The only way it was wrong was if the plow was assembled wrong since it wasn't a real easy swap to get the locking bolt on the outside. An ancient plow book might reveal the intent.
IBWD MIke
Posted: 15 Mar 2025 at 8:41am |
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8684 |
Posted: 15 Mar 2025 at 12:07am |
Mine are on wrong....
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3539 |
Posted: 14 Mar 2025 at 11:59am |
Story - We went to the auction of the AC plant in MKE. They found 2 tubs of snap couplers, one top, one bottom, one tub of springs, and one tub of rivets, hinge bolts. I bought one tub of the tops kind of by mistake. When checking out I went to the tubs and started taking top halves and mating with bottom halves , springs etc. Some dealers wife came running up and demanded I stop and put everything back - I told her the tops were of no use w/o bottom latches and we would split them. She was irate and called her hubby who was a dealer and he threatened to call security on me. I told him I had a better idea - he could have them all. He was clueless. SO, some where, probably in a new product some were by now melted down, are about 100 new snap coupler latches from the circa 1986 sale. I will not mention the old fellows name... a former Nauthurn dealer :-)
ACinSC
Posted: 14 Mar 2025 at 10:39am |
My series 1 D 15 has both set screws on the outside. There are holes on the inside but they don't look threaded. Thanks
IBWD MIke
Posted: 14 Mar 2025 at 8:40am |
Guess I've got my assignment for the day. Guess I've got 6 tractors to look at, though will probably look at more. Maybe I'll cover this in the video I'm going to shoot today?
Posted: 14 Mar 2025 at 8:16am |
Yes. There are some older ones that had only ONE hole, so there were lefts and rights early on. BUT regardless, people install them wrong !! Setscrew to the outside always.
Mikez
Posted: 14 Mar 2025 at 7:16am |
I think it was like this. the originals were 331862 and 331863, left and right, threads on one side. Then in numerical book those numbers say use 243996 which I think threads on both sides
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5163 |
Posted: 14 Mar 2025 at 7:06am |
Most latches (not all) that I've seen have threads on both sides to put the bolt on either side.
ACinSC
Posted: 14 Mar 2025 at 6:12am |
Good info Dr Allis! I'll check my D 15. Thanks!!
allischalmerguy
Joined: 11 Sep 2009 Location: Deep River, IA Points: 2893 |
Posted: 13 Mar 2025 at 10:44pm |
Thank you!
EPALLIS
Joined: 12 Sep 2009 Location: Illinois Points: 1162 |
Posted: 13 Mar 2025 at 10:26pm |
I'll have to go out and check all 5 sets. As always, many thanks to the good doctor. Appreciate it!
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1510 |
Posted: 13 Mar 2025 at 8:29pm |
I just went and checked mine as I've had them on and off a couple times for repairs. They were on correctly. And yes you can see how that squares them up. Learn something every day!!
plummerscarin
Posted: 13 Mar 2025 at 8:12pm |
Thanks for clarifying. Ive seen a number of them installed as you'd noticed and I had been wondering lately which was the correct way
Thanks(2)
Posted: 13 Mar 2025 at 7:56pm |
I was out working on a friends WD-45 diesel tonite and he also has a WD-45 gasser. Both tractors had the lift arm latches on the wrong sides. The retaining setscrew/square head bolt ALWAYS goes on the outside. This makes sure the lift latches are "square" to the lifting links and makes life easier on all the components. This applies to all WD/WD45/D-14-15-17-19-190 tractors. Setscrews on the OUTSIDE !!!!
