WD 45 F/E Loader ?? |
Author | ||
FREEDGUY ![]() Orange Level Access ![]() ![]() Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
![]() ![]() ![]() ![]() ![]() Posted: 20 Mar 2022 at 6:53pm |
Worked at a job site today that had a VERY NICE looking '45 with a front end loader on it. It had a hydraulic 2 way "dump" cylinder on it
Sponsored Links | ||
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88218 |
its got a pump and oil tank...... just add a valve stack !
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22041 |
The absolute nicest loader there ever was for a WD/WD-45 was the Allis-Chalmers 400 series "445" model loader. Live crankshaft driven pump with 10-12 GPM with a 3 gallon tank built into the left tower. None better than this loader.
Edited by DrAllis - 20 Mar 2022 at 7:39pm |
Thaks Doc for the info, the tractor was sitting in 2 inches of water due to the recent "local" rain and snow melt so I didn't want to investigate. It did NOT have any hydraulic hose hooked to the rear port so you are most certainly correct
tomstractorsandtoys ![]() Orange Level Access ![]() Joined: 11 Feb 2015 Location: wi Points: 515 |
Dr Allis how was the pump mounted? Was it underneath with a belt or did it go through the frontend block and mount out front? Dad talked about someone that had one but I never seen one. Tom
There have been pics put on this website. The pump sat directly under the radiator and was driven by the crankshaft direct. No belt. The hand crank feature was removed to make room for the hydraulic pump.
On a "side-note", We ran a straight WD with a trip bucket loader , we were able to keep the "factory headlights" in place with this loader
YEAH, Stevie doesn't give much info, does he
FreeGas ..... I answered YOUR STUPID QUESTION... You asked how you would make the WD HYDRAULIC SYSTEM work on a loader.... Multiple valve is the only way...
Now if you had asked WHAT kind of loader would you put on a WD.. Then you got a great answer from the Dr. and others..... I would have thought even YOU were smart enough to look and see if the tractor had a front mounted pump !!!
SteveMaskey(MO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Wellsville, MO Points: 617 |
Sadly, I was at the owners property this afternoon to do more work in the house, only to see the 45 parked in a different area with the lawn being mowed around her
I must re-phrase the cylinder statement, it is the SLEEVES that he said guys have issues with removing
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 1344 |
Removing the sleeves on a WD45 engine that seized while running will be the least of his problems. Better have $2000+ in the piggy bank... :-(
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8648 |
His research is junk. A wet sleeve 226 is far from impossible to disassemble.
Claims he's located an OH kit for $500 ?? He'll do the work himself. Thanks for the reply
200Tom1 ![]() Orange Level ![]() ![]() Joined: 03 Jun 2019 Location: Iowa Points: 1232 |
Mine were not hard to do. Pull the head, pull the motor, turn it upside down, set it on the frame rails, remove pan, remove the crank, and knock out the sleeve's. Mine came out with 2 of the pistons stuck inside them. Check out the oil pump while it is upside down. Give the block a good cleaning while the sleeves are out. Check the block where the o rings set. It helps if you have it on a cement floor with an engine hoist.
Apparently the engine started knocking going down the driveway grading it at finally died/seized where it sits....
sounds like NO OIL....Main bearings / crank journal turning / rod repairs........ like mentioned, liner removal is the EASY PART.
That will only be for the sleeve/piston/ring kit. Gaskets, seals, crankshaft repair, connecting rod repair, bearings, valve job, oil pump, water pump, clutch...etc... will be extra. ![]() |
corbinstein ![]() Orange Level ![]() Joined: 31 Jul 2014 Location: Oklahoma Points: 796 |
Yeah, I think I'd pop the oil pan and start looking at the rod bearings first.
Yes Steve, his description of the fail is exactly that, but the oil pan had oil in it
i have seen motor run low on coolant and overheat and cause major problems.. even tho they had oil..
either way, I would start on the bottom end. disconnecting rods one at a time should tell you where the problem lies.
One cylinder may be locked up, or one rod bearing spun. You'll find it faster under there. Head has to come off either way in the end, unless the rod bearing can be turned on the tractor, of which I don't think anyone does anymore. He may get lucky and it's a stuck piston, which can be pulled and replaced, liner and all.
