N series hydro pump output
WLHD21 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WLHD21 Quote  Post ReplyReply Direct Link To This Post Topic: N series hydro pump output
    Posted: 23 Feb 2021 at 11:24am
Does anyone know the pressure and GPM on the gleaner Hydro pump?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2021 at 11:27am
Hydro pump or hydraulic pump ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote WLHD21 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2021 at 12:03pm
Hydro- transmission. I have a Vermeer trencher that has 75 cc pump at up to 6000# psi feed it. Looking for comparable pump to match the one on the trencher,
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2021 at 4:51pm
“ Hydro- transmission. I have a Vermeer trencher that has 75 cc pump at up to 6000# psi feed it. Looking for comparable pump to match the one on the trencher,”
Just putting on a new pump is not the best approach. You have metal particles inside everything and they will rapidly take out anything introduced with out a thorough cleaning/filtering of the system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2021 at 5:08pm
I cannot visualize what you're trying to do ?? Gleaner N-series hydros are a back-to-back pump-center section-motor all in one. You can't just take the pump out of it and do something. Buy the correct OEM parts and fix it right.
