8010 lights
185turbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Topic: 8010 lights
    Posted: 08 Jan 2021 at 1:11pm
8010 is having trouble with the lights. I put all 8 lights on new.
1. When the switch is turned to hazards the hazards come on and flash but when you turn the turn signals on the side that is supposed to flash goes out and the other stays solid .
2. When the switch is turned to the road lights NO lights come on and the hazards will work like above.
3. When the switch is turned to flood lights all the lights come on
My question is why the road lights position will not turn on any lights and why when the flashers are on the the turn signal will not work right?
Thanks
185 turbocharged w/ 500 loader , WD
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2021 at 2:35pm
were your road lites HI/Lo and you replace them with the single filament??
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2021 at 7:59pm
No i replaced them with single filament lights.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2021 at 12:49am
Did lights work correctly before you replaced them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2021 at 11:22am
Yes just put new ones on
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2021 at 2:19pm
There is an updated flasher switch for the 8000 series.
Have you installed it yet?
That will make your flashers work.
Re: the driving lights, you need dual beam lights for them to work in both positions.
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2021 at 10:01am
Ok i will get the new flasher switch thanks
This page was generated in 0.073 seconds.
