4W305 - CUMMINS
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Topic: 4W305 - CUMMINS
    Posted: 12 Sep 2010 at 7:21am
I was asked has anyone installed a Cummins in the 4W305.
Which Cummins engine, any adapter plate required. If so were
does one purchase the plate and any other items required to do the conversion.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Kurzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 7:49am
Howdy WD45,
I can't answer your question but, I have seen a AC  4W305 with a cummins in. Sure changes the look of it. You lose your pipes coming out the top of the hood and this big, big exhaust pipe comes outside the cab on the right side. Me myself like the old NOS like.
Thanks Kurzy
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 8:02am
http://www.kjrepower.com
Contact these guys. C8.3 engines are replacement
Charlie
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 8:29am
An 8.3 is more suitable for a 426 replacement in a 7580/4W220. to replace the 731 I would suggest at least an L10 if not an 855.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 9:29am
I see the owners Reg. has a few 8550's listed with 855's in them
Charlie
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 9:44am
Kevin from Alabama, who posts on here, has a 4W 305 with a cummins in it. If he sees this, He'd probably give you some steps in the right direction.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 11:10am
Has anyone heard of putting a N14 in one?
jmm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmm Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 12:58pm
No, but if you can do 855, then you can do n-14
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 1:48pm
Since the N14 is the latest 855 DUH!
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 3:08pm
Talk to Everitt Hunley in Austin Indiana.
"Burgie"
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2010 at 10:11am
I just thought the N14 was rated with more power, but I know it has more electrical to it and didn't know how one would work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2010 at 11:21am
I guess I'd prefer using the Cummins L10 (10 liter) or M11 (11 liter) as both are 305 HP or more and would weigh less and be shorter/smaller/easier to fit and would match radiator capacity better than a larger displacement engine such as the 855/N14.
jmm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmm Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2010 at 1:54pm
jmm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmm Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2010 at 1:55pm
I've got a lot of respect for the M11.  I drove a log truck with a 444 cummins, little tired and poorly tuned, i'm sure, but a buddy drove a truck with a M11 with a drop axle and would run circles around me on some of the big hills around here
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2010 at 7:27pm
My neighbors had a 4W 305 with an 855 in it. I think the 855 has more torque than the tractor really was designed for. Theirs spent a little more time getting trans/dropbox repairs than they really wanted.  I have an 855 in a blue versatile and so far it has been an excellent engine. The M11 probably wouldn't have the torque, and might be a little gentler on the driveline. The M11 can make a lot of power, too.
This is what they sound like with a straight pipe. My wife says it sounds angry.
[TUBE]7Gqg2A7nx7M[/TUBE]
