Sattlite TV experts needed |
Butch(OH) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3842 |
![]() ![]() ![]() ![]() ![]() Posted: 21 May 2018 at 8:10am |
Working on a new patio and got into the satellite TV cable and cut it. Wife calls dish net and they say two weeks to get here and fix,, grr, doesn't bother me but makes wife hard to get along with. So I go to town and get a couple cooax connectors, and installed them per instructions so she could have TV until they get here to install new cable but the TV still says no signal? Cable isn't cut anywhere else and I am certain that I installed the ends correctly, I cut them off an did it twice. We rebooted the system several times to no avail, anyone with knowledge of these things know what is going on? Thanks!! Would help life at home for 14 days
fixer1958 ![]() Orange Level ![]() ![]() Joined: 13 Feb 2010 Location: kansas Points: 2434 |
I went through that before. One of the ground strands (wire wrapped sheathing under the outer cover) was touching the copper signal wire when putting the connector on. I completely understand the implications of not having the creature comforts the 'other one' needs to survive. That's all I have to offer.
Dave H ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Central IL Points: 3591 |
prob what fixer said.
So how far is it from the dish to the plug in at the house? if close like mine you could just get a roll of ready made coax and throw it above ground for an interim |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8658 |
is there a reset on splitter or anywhere?
CaseyCreek ![]() Silver Level ![]() Joined: 03 Apr 2011 Location: L.A. Points: 332 |
I second the idea of buying a new cable and running it from your receiver out to the grounding bar. Lots of people don't realize that every connection causes signal loss. And as someone mentioned earlier, not all coax splices are successful. How long of a run are you needing? Amazon is listing a 50-foot run quad-shielded with terminations already applied shipped to your door for $16 (if you are an Amazon Prime member). https://www.amazon.com/Satellite-Broadband-PHAT-SATELLITE-INTL/dp/B01GBVYAZC/ref=pd_lpo_vtph_23_bs_tr_t_1?_encoding=UTF8&psc=1&refRID=W1620XMW06M5GP7TTBTX |
D17 Series III,D17 Series IV, 185
weiner ![]() Orange Level ![]() ![]() Joined: 19 May 2012 Location: Cadillac, Mi. Points: 4304 |
Be sure and demand 2 weeks off your next cable bill.
Real heros wear dogtags, not capes.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24762 |
I'll make the assumption that there's a power supply (aka Wallwart) feeding power to the dish, if so, see if the 'power on LED' is on. If not, disconnect the coax to it, pull wallwart out of recptacle, count 10 steamboats, plug wallwart into receptacle. does the LED come on ? If so...reconnect coax. does the LED stay on " If so...should have TV.
If the LED goes off, cable is shorted,killng wallwart....find short,repair, go through all this again.... Jay |
On mine there is a section in the menu for maintenance. if I remember correctly there is a choice to test the switch. run that test. if there is a selection for signal check to see what you are getting from each lnb or whatever they call them nowadays. Too many connections can cause problems can cause signal loss but one should not be that extreme. if you go with the new cable route, the choice cable is RG6 if I'm not mistaken. There are a couple different impedance cable choices. I believe you need 75 ohm cable. It's been a while since I messed with this stuff so I may be incorrect on some of it. also if there's a radio shack in the neighborhood they will have the cable. if not, you can probably order from Walmart to pick to in the store and get it quicker then Ebay or amazon. Another option is to pick up an on air antenna for the local channels to appease her during the week. most big box have them in the store.
yep...yer gonna pay for new anyways!
Walker ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: oh Points: 8984 |
I want to know why when there is one cloud in the universe it sits between my dish and the satellite its aimed at.
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12236 |
Cuz Karma. That's why.
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3940 |
good time to get rid of the satalite dish and go back to an antanna, we did a few years ago and probly wont go back agian. all thow are antanna i mounted were the dish was and hooked in to the same cable so it sounds like a repair is still in order
Lars(wi) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Permian Basin Points: 8138 |
Wanting 2 weeks off the bill?
Now that’s funny!! I don’t care who you are Edited by Lars(wi) - 22 Jul 2020 at 2:49pm |
The lru is powered by the reciever. Your reviever should be pushing power to the dish trough thur the coax. The signal then comes back to a blocking diode at the reciver. Check for power at the coax. If dosent have power thelru wont send any signal back. Youhave to have a good connection on both vanle ends and the spli you added. You probaly dont. Ive bent the conductor to get signal where it goes into the splice about 50 % of the ones i got from walmart were defective.
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6087 |
The original post was MAY of 2018 guys... this problem has long-since gone...
