200 hydraulics |
acplowboy45
Joined: 09 May 2013 Location: connersville IN Points: 264 |
Topic: 200 hydraulicsPosted: 11 May 2018 at 10:44pm |
Was discing tonight and all of sudden the disc wouldn't raise and power steering wouldn't work..is there a spool like the 190 pumps that have to cleaned or any ideas....going to drain all fluids and change filter in morning to see if that doesn't help.
Posted: 11 May 2018 at 10:49pm |
I'm gonna guess you are very low on hydraulic oil. Take at least 5 gallons with you and figure out where it went. CHECK THE TRANSMISSION FOR BEING OVERFULL !!!
SteveMaskey(MO)
Joined: 11 Sep 2009 Location: Wellsville, MO Points: 634 |
Posted: 11 May 2018 at 11:29pm |
Splines wore out on my XT pump and it quit going down the road. Did the same as yours, no hydraulics at all
acplowboy45
Posted: 12 May 2018 at 12:20pm |
Just changed fluid and filter for hydraulics. Still no steering and nor do the lift arms lift..any suggestions.
acplowboy45
Posted: 12 May 2018 at 2:12pm |
I tore into the pump and I'm working on getting the plunger out but I keep finding little bitty pieces of blue rubber what could that be.
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2483 |
Posted: 12 May 2018 at 3:14pm |
The section seals and the seals under the wear plates are a blue Teflon material. Sounds like a complete rebuild is in order. I guess it could also be blue silicone from some previous work??
Edited by Lynn Marshall - 12 May 2018 at 3:16pm |
