WD45 char-lynn "through the hood" resevoir
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Topic: WD45 char-lynn "through the hood" resevoir
    Posted: 07 Feb 2017 at 9:32pm
I know this isn't "factory" but it is going to be user friendly. I finally have some time to work on the 53 WD that I grew up on. Dad and Uncle Kenny bought this tractor used from the Finlyn Dyer estate the year I was born, 1966, I've always known the tractor as Finlyn.
Anyway, I've been working on refurbishing her for about five years now. More looking, wondering and pondering for the past couple of years.
I wanted to be able to access the ps resevoir easily, but have also seen torch cut hoods with 8" holes in them.
I made my own mount for the tank. I used a spacer under the valve cover so the cover and gasket would not be compromised. Then welded part of a 3/4" coupler in the cap of the resivoir to fit the spare dipstick I had out of a CA rearend. That worked perfectly, just needed to add to the the length of the stick.
When cutting the hole in the hood, I started small and got a pilot hole and then finished with the plasma cutter.
Slowly but surly the ol gal is coming together. I will post pics of before and after, if I ever get to "after".
Thanks for looking.
Leon B Mo
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2017 at 9:40pm
I like it. Sure will be handy to check and add oil
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2017 at 7:15am
I think you did a really good job on it. Looks factory and I wouldn't be ashamed.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2017 at 7:15am
looks great!!!
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2017 at 9:34am
I too like it, a lot. My 45 narrow front may get that mod. It currently has the reservoir mounted on the frame rail. One of those previous owner things. Would like to get it up on the valve cover but it leeks just enough I never have felt confident moving it. I have gotten the leaks slowed way down but still like to be able to keep an eye on it without pulling the hood.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2017 at 4:53pm
Looks like it has been there all it's life. Great job.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2017 at 6:10pm
NICE !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2017 at 8:56pm
I like it too.  Mine is under the hood, so I have to take it off to check and fill it.  This would make it a LOT easier.
Leon, you are doing a GREAT job.  Keep it up and keep the pics coming!
